New Tube Amp... Dust Cover?
thetawave2
thetawave2 Posts: 268
edited November 2011 in Electronics
I've been thinking about this for a few months and I finally pulled the trigger on a Yaqin MC-100B. I bought it through Canadian Hi-Fi on ebay, as this seller seems to have a good reputation in the forums and I didn't want to take my chances with one showing up DOA from China. I won't be able to use it for a couple weeks as I'm currently away from home. Needless to say, I'm really excited to come home after over 4 months without any respectable stereo.
In the meantime, I'm considering buying a dust cover. I haven't done much research and I'd appreciate any background info, places to look, things to be cautious of, et c. I'm not looking to spend much money but I want to protect my investment, especially from our super-dusty college dorm next semester. I was also thinking it might be possible to make one. Any ideas?
My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
Post edited by thetawave2 on
  • thetawave2
    I'm also new to tubes so any miscellaneous advice about tubes more generally is more than welcome.
  • inspiredsports
    inspiredsports Posts: 5,502
    The covers on most tube amps act to protect the tubes rather than keep dust out.
    Most tube amp owners end up changing ("rolling") tubes as the originals may be inexpensive to keep the initial cost down. The Chinese 6sn7's that come stock in that particularr amp are know to be low cost and can be economically replaced for sonic improvement.
    I had a Yaqin tube buffer years ago that was very good and used the same 6sn7. I believe I substituted an Amperex Bugle Boy which was an exceptional improvement.
    I'm sure H9 and others can offer some more specific suggestions for replacements.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • thetawave2
    Most tube amp owners end up changing ("rolling") tubes as originals may be inexpensive to keep the cost down. The Chinese 6sn7's that come stock in that particularr amp are know to be low cost and can be economically replaced for sonic improvement.
    I'm sure H9 and others can offer some suggestions for replacements.
    I am definitely planning on experimenting with different tubes, just not at the moment. I know that H9 and other users have much wisdom I'd be able to learn from and I'll definitely be coming here first when I start my search for tubes.
    If dust isn't an issue maybe I'll hold off on the cover for the time being. The amp comes with a removable cage, so protecting the tubes from accidental breakage won't be an issue.
    Your Amperex suggestion has been noted :)
  • inspiredsports
    I see the yaqin.cn website (click "English" in the upper right corner) shows a modern looking cover for your unit.
    http://www.yaqin.cn/view.asp?En-63.html
    NAD SS rigs w/mods
    GIK panels
  • thetawave2
    The cage cover included with the unit will protect the tubes from breakage or curious fingers and I'm definitely happy about that. However, it won't do much to keep the dust out! Maybe it isn't such a big deal but I thought I might protect my unit from dust.
  • inspiredsports
    thetawave2 wrote: »
    Many (maybe even most) tube amps don't even come with a tube grille-style cover. Anything that would keep dust out would keep heat in. Tubes are already "perishable" and excessive heat buildup further shortens their lives (and is bad for surrounding electronic components).
    Your comment about curious fingers is accurate. You also need to know it's best to never hold a tube with bare fingers/hands as skin oil on the glass holds heat differently from clean glass. Studies show oil on the glass shortens tube life. Some use a soft cloth and other use light gloves whenever handling tubes.
    I'm not sure I'm doing it right, but dust with canned air an angled paint brush with very soft, long bristles.
    NAD SS rigs w/mods
    GIK panels
  • george daniel
    george daniel Posts: 12,096
    coverless--I wanna see the glow
  • thetawave2
    I thought trapping heat in might be a bad idea. The dust cover would be only be for when the amp was not in use (and sufficiently cooled!)
    So do you think I shouldn't worry about the dust besides cleaning like you mentioned?
  • inspiredsports
    That also :mrgreen:
    NAD SS rigs w/mods
    GIK panels
  • thetawave2
    I'm pretty excited about the glow too! I'd definitely take the dust cover off whenever the amp was powered up, and I plan to take the included grille cover from time to time to enjoy the look of the tubes underneath (the same way I leave my speaker grilles on much of the time but often take them off when listening).
  • marvda1
    marvda1 Posts: 4,941
    you can use a dust cover when the amp is not in use. or just cover the amp with a nice looking cloth when not in use.
    Puritan PSM156
  • thetawave2
    marvda1 wrote: »
    A definite possibility. The included cover will even keep the cloth off the tubes! Maybe the simple solution is the way to go here.
  • SolidSqual
    SolidSqual Posts: 5,218
    http://www.digitaldeckcovers.com/
    DDC makes some very affordable covers for all your gear. Just give them the dimensions and select the fabric and they will make you an excellent cover. I used one of their solutions for my old Pro-ject RM-5SE TT and it worked beautifully.
  • thetawave2
    SolidSqual wrote: »
    Those look quite nice and the prices I saw for some turntables (just to get a ballpark) seemed very reasonable. I will definitely consider this company as an option. Thank you for the suggestion!
    F1nut Posts: 51,707
    You do not need a dust cover and that tube cage is mainly to keep idiots that don't know better from burning their fingers. Get a can of compressed air and call it a day.
  • zingo
    zingo Posts: 11,258
    Whenever I'm swapping tubes, I just dust the unit real quick and never have any problems.
  • george daniel
    careful with that can Eugene
  • SolidSqual
    Are you so old that College dorm living predates your glory days?
    Dorm rooms are dusty as hell. The poorly filtered heating and cooling systems spread the dust all over the place. It gets in everything. The cost of compressed air over time is more than a good cover. Not to mention, the dust in these settings seems to be sticky. Without a cover, you will still smell something burning.
    F1nut Posts: 51,707
    SolidSqual wrote: »
    I had a maid. :mrgreen:
  • thetawave2
    If doling out $150 or more for an acrylic box were my only option, I'd definitely be with you on that. But something in the neighborhood of 30 bucks for a quilted cotton cover at DDC is hard to pass up....
    And SolidSqual is right. They never replace the filters in our vent systems. Even though it's a fairly new building, the amount of dust is mind-boggling. And on top of that, it IS sticky. Yuck!
    Just dust occasionally and you'll be fine. As stated, cages are just to protect your tubes anything else would cause excessive heat build up if the unit was used with a cover!
    I find that getting a box of latex surgical gloves is best for handling tubes. What's that Weird Al Madonna song? "Like a Surgeon". lol
    Yaqin products are certainly good performers at lower cost. And let's face it, many Chinese products, including my Jolida, are basically copies/mods of some older more expensive German tube amps.
    Enjoy!
    cnh
  • thetawave2
    cnh wrote: »
    Enjoy!
    cnh
    Whether I go cloth or acrylic, neither will be on when the amp's powered up. Definitely not looking to roast my amp or make pretty little Chihuly tributes out of my tubes ;)
  • zingo
    zingo Posts: 11,258
    Where do you go to school? I don't remember that much dust from my college days, but dorms can be weird places...
  • thetawave2
    zingo wrote: »
    Boston College. Aside from the dust, the housing is quite nice.
