xOver upgrade to cs350ls
SDA1C
I have ordered the exact part list from gimpods site to upgrade the xovers in my 1c. Given this part list and the values therein...whats the best match for xover parts/values for my cs350?
Also I did a quick upgrade to the caps on my 11t but not the resistors? are there any? lol(I dont know) Now is the time to do them all. Any value changes or suggestions to gain the best over all match with the 5 speaker set?
Thanks oh mighty cup of knowledge for your continued patience and candor during my times of trial LOL
1C
1C
Too much **** to list....
Post edited by SDA1C on
Here's a link to the schematic CS350LS it looks like it only takes one 5.8uF Cap.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
So then all the values stay the same as before then. I thought there were changes for some reson. If its just a replace with like value I can do that easy LOLToo much **** to list....
I am confused by the original list for the 11t. What is supposed to be silver micah? Electrolytic? resistors? ugggh!Too much **** to list....
The hardest part was getting it to fit in the hole....heheToo much **** to list....
I believe those are the by-pass caps on the Mylar caps. when using better caps you toss the silver micah. -
It sure would be nice if gimpod would do the rta series boards..(hint hint)Too much **** to list....
Skip the Silver Mica. Like pitdogg said it is a bypass cap and not needed after you upgrade the caps.
