bad mw6500's
trimettk
trimettk Posts: 15
edited November 2011 in Troubleshooting
I have 2 mw6500's from monitor 10a circa 1989. They are frozen extended. It doesn't look like the magnets came loose. I think the voice coils melted. Should I troubleshoot the crossover and if so how?
Post edited by trimettk on
  • fbm211
    fbm211 Posts: 1,488
    Youll need a multi meter and you can get new drivers from polk direct.Mention your a member and you will get a nice discount.You could try the wanted section to maybe get a better deal since 4 drivers is going to run around 200.00
    Are the tweeters OK?
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • trimettk
    trimettk Posts: 15
    Tweeters are fine and only one spkr had bad drivers. I am hesitant to replace the mids and fry them again if theres some other problem. Is there a quick way to check the crossover? I have a multimeter. Both loudspeakers read 4.6 ohmc DC resistance across the binding posts with all the drivers installed. The crapped out drivers read about 7.3 ohms each when removed from the circuit. I pulled the xover out and nothing looks bad on it. Monitor 10a circa 1983. Thanks!
  • trimettk
    trimettk Posts: 15
    Never mind. The magnets are loose. Thanks!
