virus got my pc
fbm211
fbm211 Posts: 1,488
edited November 2011 in The Clubhouse
Another one of those damn companies hit my pc with the buy our software to fix your pc.
It looked as though win7 was taking care of it by scanning and fixing the problem but after it was done I got the buy our virus protection and repair your pc message/popup.
I lost all my favorites in IE and my raptor D drive is showing up as empty even though it says 1.77GB free of 34.4GB.
I cant see why IE favorites is gone since I opened google chrome and was able to import them over.They just dont show up in IE.
I was able to go into safe mode and do a system restore but I am still missing the favorites and drive d is still showing as empty and windows says I need to format it to use it.Damn I had a-lot of info on that drive I cant replace either.Another wierd problen is I keep getting these internet radio commercials just starting up on thier own without starting anything to open it.
Time for a win 7 fresh install.....Later.
SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
Post edited by fbm211 on
  • Sherardp
    Sherardp Posts: 8,038
    If you have a spare computer or HDD, you could run that corrupted drive as a slave and attempt to recover some data that way. I would try safe mode without networking and see if you can get in that way as well ( though you mentioned it without saying which you mode attempted). Not sure what else you can try other than running CCleaner, MS Security Essentials, Malwarebytes and attempt to remove any correction via those apps . If those end up working for you, I would recover the data you want saved via CD or thumbdrive. Afterward go for the fresh install of W7. External HDDs are your friend, always keep a back up of your system .
  • markmarc
    markmarc Posts: 2,309
    Personally, I'd do a complete "nuke and repave" of your hard drive. I do it twice a year on my wife's desktop to keep it fresh and speedy.
    Former Staff Member TONEAudio
    2 Ch. System
  • inspiredsports
    inspiredsports Posts: 5,502
    markmarc wrote: »
    Unfortunately, that's a great idea. I say unfortunately because there should be a better (less time consuming) way. The Windows registry is an abomination and begins growing and slowing performance about 1 second after you install Windows.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • BeefJerky
    BeefJerky Posts: 1,320
    markmarc wrote: »
    You're doing it wrong! No, seriously. If you have to re-image a computer on a regular basis with a modern OS, you have a real problem. When I say modern OS, I'm referring to WindowsXP (SP2+), Windows Vista, Windows 7, or Mac OS X. Even though Windows Vista had its issues with the RTM version, none would have necessitated a re-install, just an overlay of SP1. Also, even though not modern, Windows 2000 was rock solid as well.
    If you are re-installing that often, your likely candidates for problems are:
    1) Bad hardware - this happens more often that one may think, and depending on the exact problem and severity, it can cause a slow corruption of files.
    2) Incompatible hardware - it shouldn't happen in this day and age, but it still does, and can mimic the same symptoms as bad hardware.
    3) Improper initial install
    4) Bad drivers - obviously, the problem here is the particular manufacturer, but it is still a real issue. If you can't find reliable drivers, then get different hardware.
    5) Bad software - blame the developer, not the OS. It is pretty rare that a piece of software will ruin an OS install nowadays, so this should be low on your suspects.
    6) User problem - this includes viruses and spyware since it is nearly always a stupid move by the user that lets the infection occur. This is very common.
    Back in the Win95/98/Me days, the registry was a big culprit in terms of problems. However, that isn't a real issue anymore, despite the inaccurate claim that many users make. If your OS install is having problems, there are other actual issues that are the real cause, and they are listed above.
  • WilliamM2
    WilliamM2 Posts: 4,807
    As stated above, if you are unable to clean it up, try to get the data by connecting to a different computer. If you do end up re-installing, use the built in utility in Win7 to create a disk image, in case you have the same issue in the future, or a hard drive failure. Also use the built in backup feature on a weekly basis to back up data to an external storage device.
    Win7 action center actually warns you, and asks you to create these backups. Too bad most just ignore it. Microsoft can only do so much to make the OS fool proof.
  • nadams
    nadams Posts: 5,877
    FBM - your raptor drive is NOT empty. Go to Tools - Folder options - View - and check the box for "show hidden files and folders". I've seen this many times... the software goes through and hides all your files so you think that the drive is empty. Cleanup can be done with a mix of MalwareBytes and your favorite virus scanner. Sometimes these can get more involved than that, though. I often have to hook drives up to my PC and scan them there, as the fake antivirus software blocks installation of MalwareBytes, etc. Once MB cleans off the main fake av executables, I pop the drive back in the original PC, and can usually then install and run MB there. That takes care of the registry hooks and other nastiness.
    Ludicrous gibs!
  • Rivrrat
    Rivrrat Posts: 2,101
    Malawarebites and Combofix.
    Sometimes you need to reload IE after Combofix, but I've always had my stuff come back.
    Good luck
    My equipment sig felt inadequate and deleted itself.
    billbillw Posts: 7,556
    Doesn't anyone use the backup features in Windows 7? Weekly backups!!! I also store all my videos, photos and downloads on separate drives/partitions from my C:drive. Worst case, you restore from 1 or 2 weeks ago and maybe loose a few few emails (and usually not because I have my servers keep messages for 30 days, so they repopulate once I sync again).
  • dee1949
    dee1949 Posts: 1,425
    ...did you try this. i know i removed it from a friends computer a while back. Forget exactly how, but required Malwarebytes. Read "post replys" on site below too...they also have tips.
    http://www.howtogeek.com/57837/how-to-remove-win-7-anti-spyware-2011-fake-anti-malware-infections/
    Removing Win 7 Anti-Spyware 2011
    Download a free copy of MalwareBytes, copy it to a thumb drive, and then install it on the infected PC and run through a scan. You might have better luck doing this in Safe Mode.
  • fbm211
    fbm211 Posts: 1,488
    Ive got my main rig back up and running.I used my XP disc to format the VelociRaptor drive and then installed win7pro.
    So would it be OK to plug the raptor back in? I downloaded the microsoft virus protection software they provide for free but I just dont want any virus remaines to reinfect the rig.My other rig does not have sata support so I cant use it.
  • fbm211
    fbm211 Posts: 1,488
    Thanks for the suggestions guys.
    5 minuites after installing security essentials it caught a trojan while I was at the bioware site to download patches.
  • WilliamM2
    fbm211 wrote: »
    Why didn't you just use the Win7 DVD to format the disc? To answer your question, after a format, there will be no remnants left, of course all your data is gone as well. And you didn't have a virus, you had malware.
  • gmcman
    gmcman Posts: 1,849
    If you don't have a 2nd HD, then a 1TB Caviar black would be great as a backup.
    As stated above, go into safe mode, move all your keeper files like pics, movies, etc onto the new HD, then if you have to reinstall your OS then so be it.
    Not sure what AV you are using, but since I have been using Microsoft Security Essentials (MSE) I have not had one problem, crash, etc..and it's free. Best AV I have used, go figure...they have a name to protect.
  • fbm211
    fbm211 Posts: 1,488
    I tried to use the win 7 dvd to reinstall but every time I clicked to install it would not go ahead.It would hang for a second or so and then ask to choose upgrade or custom install again.Every time.
    I have three drives and two were connected at the time the malware hit.Im just wondering if it got onto the 2nd back up drive.
    It certainly affected my majic jack.Windows reported it had a couple problems when I hooked it back up but scanned and fixed two problems it found.
  • gmcman
    gmcman Posts: 1,849
    I had a virus on my last pc before I built this one....really dug in deep. I went into safe mode and condensed one of my drives to another to allow for a format then transferred all of my documents, pictures, music, videos, favorites, all back onto the clean drive.
    Then I just went ahead and did a fresh install of Win 7 and had no issues since.
    I was using Avast AV at the time but this rig has MSE. Zero issues for 1 year so far, last build was Win XP....never would I mess with Vista but that's just me.
    If you have precious memories on your HD then I would get them to a safe place now.....you never know what has buried itself in there.
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    fbm211 wrote: »
    I have some experience here, I hate those damn asses pop ups etc. they suck. before installing something if the internet works google it and it'll say if it's a virus or not. Restore worked for me one time but it sounds like it didn't work all the way since you're getting that radio station thing come up and your drive is showing it's empty.
    The fresh install will fix your computer, Good luck with all that.
    and the missing info can be restored but I don't know they do that. my hard drive completely died one time and the guy that was going to fix it asked for the dead drive to get the Drivers off of it so if he can do that somebody can get that info off your drive for you.
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
  • mantis
    mantis Posts: 17,411
    I'm so sorry you have to deal with all that. I gave all that up years ago. Do yourself a favor and get a Mac. I have yet to have any of those problems.
    Only thing now is rumor has it people have been trying to hack into Mac and give them virus/Malware etc. Doesn't anyone have anything else better to do with ones time?
    Dan
  • BeefJerky
    mantis wrote: »
    Well, since the market share has been increasing for Apple, it is no surprise that there is interest in creating viruses/malware for it. It was bound to happen really.
    However, a Mac isn't the end all be all of problems. Modern Microsoft OS's are perfectly stable (XP SP2, Vista, Win7); we are no longer in the awful Win95/98/ME days. I haven't had a virus infection in many years on any of my Microsoft OS's, however, I take precautions. I run a virus scanner, and avoid visiting sites and downloading things that are likely to bring about a virus. It's really just common sense; however, I realize that it is not something that is actually common anymore.
  • Mr. Sharpe
    Hackers sit in front of the computer all day everyday 24/7 and hack stuff. like you said Mantis, they don't have anything else better to do.
    this guy on Yahoo! said "hackers can steall all the money you make in a week in 5 minutes, I'm pretty sure they have lives". Yep, I guess if you enjoy being a thieving **** I guess it's okay then.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • WilliamM2
    Keiko wrote: »
    Awwww...sad liitle man living off the government's teet, can't take his own medicine. Bummer.
  • WilliamM2
    Keiko wrote: »
    Awwww...sad liitle man living off the governments teet, can't take his own medicine. Bummer.
  • Sherardp
    Mr. Sharpe wrote: »
    This not true at all. Not all are evil. It's like having a Super Power, some use it for evil , I use it for good. See post 2, it was spot on with the fix. OP glad your in the clear.
  • Mr. Sharpe
    Ah I see.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    One word
    ESET
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
