Cs8080hd
Question? I have lsi15 fronts and lsifx rears driven by outlaw 755. Appreciate any advice of how the CS8080HD would work with this setup. I had a lsic but the speaker is blown and I wasn't that impressed with it anyway.
Thanks!
Thanks!
Post edited by mau on
Basically sell all the LSi speakers and get the BP 8080's from Def Tech if you really like that center channel. It' a fantastic system and crazy dynamic. I believe after owning Lsi's this setup will blow you away for movies. Music the Lsi's can hang in there as they are very nice musical speakers. But if theater is your game , then game on my friend.
NO , the CS8080HD will not match up well with your LSI system , the LSI center is a perfect match and if you feel it's not , then you don't like the LSI's. I stand on that.Dan
There are few competitors in HT that can hang with Definitive. IMO.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
