Need Crossover for RT2000I
rdobroski
rdobroski Posts: 2
edited November 2011 in Troubleshooting
I recently had a crossover go bad and beyond repair. It is very charred and some of the capacitors are no longer attached. I called Polk for a replacement, but they say the part is incative. Does anyone have a spare for sale or a solution. I would hate to give up my speakers over one part.
Post edited by rdobroski on
  • rdobroski
    rdobroski Posts: 2
    edited October 2011
    Kim wrote: »
    I would recommed downloading the schematic and then contact the folks at Madisound.
    They will be able to custom fabricate new cossover assemblies.
    You can have some fun upgradinging the caps and resistors.
    I would suggest replacing both.
    Wow, thank you so much. I called them and they said exactly what you suggested. I will look for the schematic. I assume it is on this site somewhere.
  • alanh01
    alanh01 Posts: 3
    edited October 2011
    Hi-
    I need a schemtic for db6501 crossover. Where can I find this? email me if you know where I can find one.
    alanh01@msn.com
  • jimgebhard
    jimgebhard Posts: 1
    Hi Kim
    I have some severely burned Atrium 7 crossovers . I will be replacing open drivers and tweeters. Is the schematic for the crossover available?
    Sincerely
