Best speaker position in a room for LSi15's?
Ducati Guy
For all you guys that have LSi15's,
what have you found to be the ideal speaker placement.
I have been told in general,
to place the speakers 7-10 feet apart from each other.
to place the speakers 2-3 feet away from the back wall (to improve the depth of the soundstage).
at least 2-3 feet away from room corners.
to "toe in the speakers" for a more precise center image/voice.
And to make an imaginary triangle between the listening position and the 2 speakers.
Your on track with a few holes.
The speakers should be 3/4 the distance apart as from the seating location. The distance lets say is 10 feet , speakers should be 7.5 feet apart. Toe in should be fired directly behind your head . You should see the inside sides of the speakers but not the outside. Off the back and side walls is ideal for smooth natural bass response.Dan
