Tweeter Gaskets
brgman
brgman Posts: 2,859
edited October 2011 in Vintage Speakers
I am going to send a sample to see what these cats can do for us on tweeter gaskets.
Now i have 2 styles here.The oval ID and the round ID with cutouts where the plugs set in to the speaker housing.
is there a preference?
The round one isn't as flimsy as the old oval style but not sure if it will work for everyone.
Feedback please.
I’M OFFENDED!!!!
Post edited by brgman on
  • Big Dawg
    Big Dawg Posts: 2,005
    edited September 2011
    Not sure which is which, but if I had to guess I need the flimsy oval type. Pics?
  • CNWDI
    CNWDI Posts: 91
    Right now I've got 2x SL2000. Those will soon be replaced with 2x either RD0194-1 or RD0198-1 depending on what I manage to assemble towards a TL crossover. I guess the next question I need to ask is, "between the oval and round ID, which one makes more sense for what tweeters?" Since I can't answer that second question, I can't really give a useful opinion on your first question.
    Current polk speakers:
    Family room 5.1: TC265i R/L, VM10 Center, RC65i surrounds (couldn't match the TCs)
    Basement non-dedicated 7.1 HT: SDA-CRS+ R/L, 255c-LS Center, LSiFX surrounds, RC80i in-ceiling rear surround, plus Wharfedale 12" sub (some day I'll get around to building 15" F-20 sub).
    F1nut Posts: 52,002
    This one, "round ID with cutouts where the plugs set in to the speaker housing."
    Toolfan66 Posts: 18,189
    This One!!!!! I will take 20 of them!!!:cool:
  • brgman
    brgman Posts: 2,859
    That's the way i'm leanin'.They fit nicely on the RDO's which most of us eventually use.
    I’M OFFENDED!!!!
    heiney9 Posts: 25,504
    I'm in as well for lets say a dozen
  • gimpod
    gimpod Posts: 1,793
    I'm in for 6 of these please.
    nooshinjohn Posts: 26,001
    Armacell works...
  • dcmartinpc
    dcmartinpc Posts: 844
    This one for me. I am in for 20.
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • brgman
    brgman Posts: 2,859
    There will only be one kind ordered and that will be the round with cut out style.
    I’M OFFENDED!!!!
    Armacell works...
    Seriously John??? You are the first to jump down someone's throat that thread craps and now you do it :rolleyes:
    pitdogg2 Posts: 27,325
    in for 8
    as long as they fit sl1000/2000 or RDo194's in the future
  • brgman
    brgman Posts: 2,859
    IF this works out they will fit PLASTIC faceplate tweets.
    SL2000
    SL3000
    and RDO's
    they won't fit the 1000's or Peer's due to a size difference in the plate as well as the position of the connecting tabs.
    I’M OFFENDED!!!!
  • rromeo923
    rromeo923 Posts: 1,513
    Armacell works...
    I suspect that these gaskets will be better than Armacell. I am correct in this assumption??
    Currently my tweeters are Mortited. I do have some Armacell sitting around since I just did the Armacell thing w/the mid drivers and the passive while installing Larrys Rings.
    I got static in my head
  • brgman
    brgman Posts: 2,859
    they'll be the best i can have stamped out by the company
    if you want armacell,buy armacell
    no good deed goes unpunished does it?
    I’M OFFENDED!!!!
    brgman wrote: »
    Yep, no matter what you do to please people, someone has to crap all over it and in your own thread no less.
    No one said every member here had class.
    Good job brgman, what you are doing is appreciated by many. John is a class A putz, always has been, always will be.
  • Joe08867
    Joe08867 Posts: 3,919
    Armacell works...
    Dude why are you such a ****?
    If you don't want them you don't have to buy them.
  • CNWDI
    CNWDI Posts: 91
    It's probably a good thing that these aren't showing up immediately...it gives me a chance to figure out when I'm going to dismantle my speakers for these, MW gaskets, Larry's rings...and hopefully more.
    Many thanks to brgman, TFLF, gimpod, DK, and the others here who keep coming up with great ways to help folks like me who might otherwise be on the fence about tweaking a "perfectly good" pair of 25-year-old speakers...
  • eandrade
    eandrade Posts: 20
    Put me down for 8.
    -Ernie
  • hookem1969
    hookem1969 Posts: 9
    I am in for 8 myself. Thanks I have been needing some since mine are 25 years old.
  • headrott
    headrott Posts: 5,496
    I will vote for this one: "round ID with cutouts where the plugs set in to the speaker housing" as I believe that's the one most (if not all) SDA's use. Thanks again.
    Greg
  • xoaphexox
    xoaphexox Posts: 247
    I'm in for 8 of whatever kind works with RDO-198's in 1.2TL's :)
    Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
  • nspindel
    nspindel Posts: 5,343
    In for ten please. Thanks for doing this!
    heiney9 wrote: »
    Sorry man... no thread crapping was intended. I mis-understood the purpose of the thread. I had no idea NEW ones were being made. I am and always have been supportive of anyone's efforts to improve the breed. I appologize for mis-reading the purpose of the thread.:redface::frown: If they come to be, put me down for 6.
  • intangible
    intangible Posts: 262
    I would like two.
  • brgman
    brgman Posts: 2,859
    Cool!
    Thanks for stepping up John.
    I’M OFFENDED!!!!
  • greybeard
    greybeard Posts: 60
    Thanks for doing this, and please put me down for 20 tweeter gaskets for the rdo series. - greybeard
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Posts 29 & 30 reported!
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • inspiredsports
    inspiredsports Posts: 5,502
    In for 6 please. Thanks!
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • CNWDI
    CNWDI Posts: 91
    I'm in for 6 as well.
