Critical for speakers to be level?
pogi
pogi Posts: 11
Hi,
Got 3 new Polk speakers.
Is it critical for speakers to be as level as possible, like on a horizontally (or vertically like on a wall) level surface? Like do I have to use a level (bubble) on them?
Just curious if the driver/coil would not be as free moving, if the enclosure is not level...
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited September 2011
    No need for a bubble level use your eyeball and they will be fine. Unless you have vision problems in which case use a level.:biggrin:
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
    F1nut Posts: 52,365
    The short answer, yes.
  • pogi
    pogi Posts: 11
    Thanks for confirming my hunch F1nut. Sorry for the double post, it shouldnt happen again.
  • TNRabbit
    TNRabbit Posts: 2,168
    It depends greatly on the speakers & your level of OCD~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • apphd
    apphd Posts: 1,514
    TNRabbit wrote: »
    ^^^^I follow this thought about it. With very good high res. equip., probably. For most, as long as you maintain the same plane with a pair of speakers and are "eyeballed" up for individual level I think you're fine. My thoughts a tape measure would be a more useful tool. But assuming you have a level, this is free which makes it nice, but there is probably so many other things that would yield more. Location, room treatments, etc.
  • inspiredsports
    inspiredsports Posts: 5,502
    pogi wrote: »
    . . . thanks for confirming my hunch F1nut . . .
    And yes, use a level.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Posts 8 - 10 SPAM reported!
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • rebuy
    rebuy Posts: 694
    Speakers have to be level so the sound doesn't fall out of the hole in the box.
    Check and see if you have a hole.
  • mantis
    mantis Posts: 17,656
    pogi wrote: »
    Hi,
    I'm completely not understanding this question. To answer what I believe is your question , the driver/coils will be just fine 360 deg. You can mount your speakers upside down for all the driver and could care. Gravity doesn't play a part on if the speakers are level or not. Now sound direction has a huge part on how your speakers are positioned.
    From re reading your question, what is your real concern? I do however suggest if you care starting a general speaker knowledge journey and get your feet wet. Then some of the things I tell you will make more sense when the time comes.
    Dan
