Looking for good receiver for Polk Mon 70's
paulgj
Hello,
I have a pair of Monitor 70's (Series II) and a PSW10 and am trying to find out what kind of receiver would be a good match for these speakers in a 2.1 configuration. I'm particularly concerned about getting enough power for these speakers and having good specs to drive them as well as possible without damaging them.
When looking at Receiver specs I see a lot of confusing info such as two sets of numbers for say "Front L/R" ratings", one will be say 80W+80W at 8 ohms and another at 110W+110W for 6 ohms at a different Khz rating. I'm still trying to figure out exactly what this means, but am trying to get an idea of what to look for and what to avoid
Also are there any particular features to look out for with regard to the Subwoofer connection on a receiver?
Any suggestions or tips, links etc. would be greatly appreciated.
-Paul
-Paul
HK 3490, Pair Monitor 70's (series II), PSW505
Do you plan on going with a full theater down the road? If so then look no further then Pioneer Elite VSX52 or VSX53. These receivers will power your monitor series speakers beautifully . Not to mention have the latest in technology and coolest things like Airplay and 3D.
Even if 2.1 is all your going to use , this receiver sounds sweet for music and has plenty of dynamic range to make those Monitors sing.
http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+ReceiversDan
thanks Mantis, that's a little more than what I wanted to spend, sorry should have mentioned that (would like to kee below $500 if poss). Yeah, sound quality is more important that home theater stuff right now, mainly looking for just a good music listening experience, not too interested in hooking up to Blu-Ray or TV at this point but would consider in the future.
What would be a min power rating that would be OK to use with these speakers?.HK 3490, Pair Monitor 70's (series II), PSW505 -
Reported entire thread!DARE TO SOAR:
This is a pretty smoking deal and will provide your monitor's with plenty of power.
http://www.newegg.com/Product/Product.aspx?Item=N82E168821152742 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Or for more coin, http://www.newegg.com/Product/Product.aspx?Item=N82E16882115275
Very robust internal amplifier2 Channel in my home attic/bar/man cave
Thanks for the tips, I am interested mainly in music so I got the Harmon Kardon HK 3490.HK 3490, Pair Monitor 70's (series II), PSW505
Not a bad choice. HK's have notoriously had some of the beefiest internal amps too, so you'll be more than good on power2 Channel in my home attic/bar/man cave
