Will a CSi5 work properly in a TV cosole?
breal74
breal74 Posts: 324
edited September 2011 in Speakers
I am looking to buy, or build a new TV console and was wondering if my CSi5 will work properly in the center channel shelf since it is rear ported? Would I need to need to cut out the rear panel of the shelf if it has one? Or, is it better to set it on top of the console? Thanks.
Post edited by breal74 on
  • mantis
    mantis Posts: 17,559
    I like Center channels free standing , they always seem to perform their best. But inside a cabinet if there is proper room , no 1t order reflections and the back is open , you can put it in there with no performance loss. It looks much better inside a cabinet for a clean look.
    Just make sure it's not to low , try to get it at hear height about 42 inches to the tweeter or angle it up so where your seating location is , the tweeter fires directly at it.
    Dan
  • breal74
    breal74 Posts: 324
    Thanks for the info mantis. I think that I will be building one because I can't seem to find what I want. Time to pull out the wood working tools.
