Rti8 or Fxi3 for surround??
nhhiep
nhhiep Posts: 877
edited August 2011 in Speakers
I recently bought a set of RTi12 and Fxi3 for $330 on CL to replace Rti8 set.
Between the rti8 and fxi3, which do you think sound better as surround speakers? Power isn't an issue, since my Denon AVR 3806 only power the rears, HK signature 2.1 powers front and center.
Post edited by nhhiep on
  • B Run
    B Run Posts: 1,888
    edited August 2011
    Really depends on you. What sounds best, what fits your room best, and what kind of surround you like. I prefer the Fxi's for surrounds but some prefer towers.
  • mantis
    mantis Posts: 17,321
    edited August 2011
    I prefer surround to be surrounds on wall mounted in correct position and height. Floor standing speakers simply can't do such a thing unless you build platforms for them or into the wall in the correct position. This is a waste of time effort and money.
    Use the Fxi3's and put the Rti8's in a 2 channel system or ebay.
    Dan
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited August 2011
    I've never had a problem running towers as surrounds. If I still had the space, it would be my preferred choice.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • pdxfj
    pdxfj Posts: 376
    edited August 2011
    My vote is for the FXi. When properly placed, they create a very open rear sound stage that makes it difficult to locate where sounds are coming from. Di-Pole mode works best for this, but also try Bi-Pole to see which you like better.
  • mystik610
    mystik610 Posts: 699
    edited August 2011
    My vote is also the FXi3. Dipoles have more of an impact when used as surrounds than a tower would.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
