Blown drivers in RTA12C's?
HTguru1982
HTguru1982 Posts: 1,066
edited August 2011 in Troubleshooting
I noticed this the first day I bought them but wasn't sure if it was a problem. All of the midrange drivers SEEM to be working in my RTA12C's. They produce sound at least. In a particular scene in Transformers 2, the sound shifts to the front 2 speakers and during this transition, the RTA's sound somewhat distorted, at least compared to my other speakers. This apparent distortion is only noticeable on this one scene in this one movie. :confused:
I was messing around with my "new" Monitor 7's(thanks intangible) and decided to compare them to the RTA12's. I moved them up front and listened to the same scene from Transformers and no distortion. I thought it was weird so I decided to try the push test on both RTA's. When I did, I heard/felt scratching on EVERY midrange driver. I did the same to the Monitor 7's and absolutely no scratching.
When I push the drivers in on both sets of speakers, the passive radiator moves with them. I can't remember but I thought I read that if the drivers were blown, the passive radiator wouldn't move during the push test although I've done so much reading on these speakers over the past week that I could have gotten that info mixed up.
I hope there's nothing wrong. I want to upgrade the tweeters as well as the crossovers but if I have to spend more money to replace all four midrange drivers then I think I'm going to have a meltdown. My fiance will probably kill me first, though.
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
Post edited by HTguru1982 on
  • drumminman
    drumminman Posts: 3,396
    edited August 2011
    The scratchiness during the push test is a bit of a worry. The fact that they only sound off during that one scene in that one movie - not so sure.
    Have you tried playing music through them?
  • HTguru1982
    edited August 2011
    I haven't yet. I'll hook them back up shortly and go through some troubleshooting steps. Perhaps they're not all damaged.
    I came across some MW6600X drivers on Ebay. Would these suffice as replacements drivers?
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
  • drumminman
    edited August 2011
    Those are what's in my 12C's. To be sure pull one of your drivers and read the info on the paper tag on the back - the driver number should be there.
    I don't think Polk makes replacement drivers for the RTA 12's any longer, but you can call them and ask.
  • HTguru1982
    edited August 2011
    That's the thing - I've been trying to pull them out for 2 days now. I can't get some of the screws holding the drivers in to budge. I'm afraid that if I keep forcing it, I'm going to end up stripping the screws.
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
  • HTguru1982
    edited August 2011
    Ok, finally got one of the drivers out. It is the MW6501. I found an old thread where someone mentioned the parts list Polk use to have on the website. It listed the MW6501 and the MW6600X as being the same driver. And if the MW6600X is what you have in your RTA12C's drummin, wouldn't it be a safe bet that they will work in mine? Thx!
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
  • drumminman
    edited August 2011
    HTguru1982 wrote: »
    All that sounds logical - should work.
  • geoff727
    geoff727 Posts: 546
    edited August 2011
    HT,
    It sounds like your MW drivers in your 12's have mis-aligned voice coils, causing the coil to rub in the gap at a certain level of cone excursion. Unfortunately, this is a recipe for eventual failure of the drivers......unless, of course, you never play 'that one scene' in Transformers 2.:wink:
    G~
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS-II (modded)
    Infinity RS-IIIa (modded)
    Infinity RS 2.5 x 2
    Magnepan 1.6QR (modded)
    System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373
  • HTguru1982
    edited August 2011
    I'm going to order the replacements from Polk, the 6503. $60 a pop - gonna have to do something real nice for the old lady lol.
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
  • rmaiers
    rmaiers Posts: 145
    edited August 2011
    I bought some replacement MW drivers for my 12Bs from Polk and they charged $48.00 with free shipping if you tell them you are a Polk member. Hope that is still the case.
  • rmaiers
    rmaiers Posts: 145
    edited August 2011
    If you do get them from Polk, make sure you check the screw holes are cut away from the rubber surrounds or they will catch and tear the surrounds when you put them in. I learned that the hard way.
  • HTguru1982
    edited August 2011
    Thanks for the heads up!
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
