LSi15's...considered neutral?
pearsall001
pearsall001 Posts: 5,093
edited August 2011 in Speakers
I'm leaning pretty much to a neutral presention, what are your thoughts?
Post edited by pearsall001 on
  • mantis
    mantis Posts: 17,204
    edited August 2011
    For the most part with a weak mid bass. The Highs are nice but sometimes sound restricted. Bass is lose and not very defined. I remember reading about a woofer replacement awhile back that address this very problem. Also crossover upgrades suppose to really make the Lsi15 sing way better then factory.
    If your loving those 15's you should consider the upgrades. They are nice speakers on their own.
    Dan
    EndersShadow Posts: 17,596
    edited August 2011
    mantis wrote: »
    You replace the stock woofer with a Polk db840 single voice coil sub. I did this and the bass is quite nice
    Wait till crutchfield has a buy one get one 1/2 off before buying
    treitz3 Posts: 19,222
    edited August 2011
    Not at all.
  • Face
    Face Posts: 14,340
    edited August 2011
    If powered by a good amp, neutral to warm.
  • pearsall001
    edited August 2011
    Face wrote: »
    That's been my impression running the Rotel RMB-1095 multi-channel amp. Plenty of good juice feeding those puppies.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2011
    Certainly leans towards the neutral/warm side. You can add some silver in your wiring to help add some sparkle to the highs though.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
