monitors 70's problems
ginnyman2011
I have my monitor 70's hooked up to a onkyo tx-608 and yesterday i had them at a loud volume and they sounded great, but today they sound distroted can someone help please.
Post edited by ginnyman2011 on
ginnyman2011 wrote: »I have my monitor 70's hooked up to a onkyo tx-608 and yesterday i had them at a loud volume and they sounded great, but today they sound distroted can someone help please.
Were you playing a cd?......Did you get a high-gain warning on the Onkyo from your Dac or cd player?
Too much gain can damage your speakers.peter. -
i was listen to a cd but i didnt't get a gain warning.
i was using a ps3
ginnyman2011 wrote: »i was using a ps3
I use a Pioneer Elite receiver and it has a high-gain warning light.I'm not familiar with the Onkyo and whethet it even has a high-gain indicator.
I do know that the 70's have a sensitive tweeter that can be easily blown at high volume.Did you try to hook up a cd player to see if the problem might be the ps3?.
If the problem re-occurs,I suggest that you send an email to Polk and explain the problem.They are very helpful.Peter -
Thank you for all the help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I think there might be something wrong with my tweeters all of other speakers sound fine , I need to do some more trobleshooting to see if it's my the ps3 is the cause of this. Again thank you -
ginnyman2011 wrote: »Thank you for all the help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Good luck,buddy.....Let me know if everything works out.....peter -
So it's my ps3 i hooked up my laptop to my AVR and they sound like should.
I'm so!!!!!!!!!! happy!!!!!!!!!!!!!!!! -
ginnyman2011 wrote: »So it's my ps3 i hooked up my laptop to my AVR and they sound like should.
Life is good,my friend
