Receiver for RTi-A7
Hi Guys,
Last week I got my new RTi-A7 speakers which connected to my
YAMAHA RX-V565.
I would like to upgrade the receiver and to buy a new one.
Which one can best fit to the RTi-A7?
Thanks,
Shmulik.
YAMAHA RX-V565.
Thanks,
Shmulik.
Post edited by salfand on
Sounds like the new pioneer Elite SC-57 or the SC-55 is worth looking into,check the thread regarding these it sure has sparked my intrest.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
Thanks for the quick reply.
I will look into it. -
Or a cheap avr with preouts and a parasound amp.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
DittoDan
I tend to agree with this more . At accessories4less you can check it out for Marantz or Onkyo if you want to keep it on a budget , the Pioneer the new Elite 53 is also a option but less priced than the 55 or 57 . There`s a lot of options out there .
Are you looking for a receiver to your mainly music listening or to your normal 5.1 , 7.1 etc system ???
Regarding the amps , after you have a receiver with pre-outs you can take a look at Emotiva , Outlaw or Parasound . -
Yeah, I would second Pioneer Elite SC models but you could fine a SC-35/37 for cheaper.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
Receiver: Pioneer Elite SC-35 (140 watts x 7)
Amplifier: Adcom GFA-555 Mk.II (200 watt @ 8 ohms)
Sub: Polk DSW PRO 500 (10 inch, 200 Watt)
TV: Samsung 59 inch 3D Plasma 600 Hz PN59D7000
Sources: Samsung BD-D6700 3D Blu-ray Player, DirecTV, PS3, iPhone 4 and IPod Classic with Apple Lossless Tracks -
I am looking for receiver mainly for movies (80% movies 20% music) -
I would like to upgrade the receiver and to buy a new one. Which one can best fit to the RTi-A7?
An SC-35 or 37. http://www.unitedonlineshopping.com/Political Correctness'.........defined
President of Club Polk -
What F1nut said. The ICE amps on the Pioneer SC units will power the RTi A7s sufficiently until you decide to get an amplifier.
But I agree w/ the Parasound suggestion as well. They definitely mellowed out some of the brightness of my RTi A7s.ALL BOXED UP for a while until I save up for a new place
Home Theater:
KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
2 Channel:
Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs -
Porter1173 just posted a thread in Electronics showing a link to Costco where they are selling the Pioneer SC-35 for $749. That would be a good match for the RTiA7's.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
2 Channel.............................
Yaqin MC-100B
Energy RC-70 Speakers
Arcam CD-192 Disc Player
Van Den Hul Interconnects -
Thanks guys for the suggestions.
Do you think that Pioneer is better match to the Polk Audio RTi-A7 than the Yamaha? -
Do you think that Pioneer is better match to the Polk Audio RTi-A7 than the Yamaha?What F1nut said. The ICE amps on the Pioneer SC units will power the RTi A7s sufficiently until you decide to get an amplifier.
I agree with this, you might not even want a amp.Fronts: Polk RTi A9
Center: Polk CSI A6
Rears: Polk RTi A7
The Pioneer should be less bright than the lower end Yamaha. If you get the SC series you will not likely need an amp. It also has better Dac's than a lower end Receiver and better overall components. Thats why I went with the SC series. I did it this way even though it cost more, because I wanted the better Receiver with the option of adding an amp if required. I don't plan on getting an amp at this point, as the Receiver is great on its own. You would likely come to the same conclusion.Home Theatre.............
Pioneer SC-35
Polk RTi10's Fronts
Polk CSiA6 Center
RTi4 Surrounds
SVS PB-12 Sub
Yaqin MC-100B
I just bought an SC-35 yesterday and like the sound better now without my Adcom, it's more than enough for my Rti8's.
Just FYI - Newegg is having a sale this weekend on the Yamaha RX-A2000 - supposedly the new Yamahas aren't as bright as the old lower end ones. $1399 - $500 with a code (EMCYTZT665). I think this is the 2nd model from the top - all the current bells & whistles, 130wpc. And it's 35lbs which is decent heft.ALL BOXED UP for a while until I save up for a new place
Home Theater:
2 Channel:
I demoed a RXA2000 yesterday when I picked up my Elite. It sounded really nice and smooth, especially for music. It was hooked up to some Paradigm studio bookshelves and wasn't bright at all.
