SDA 2 mod recommendations
Tekkis
Seems i have an odd set of SDA 2. This is a 3MW and 2 sl1000s version with 2 fuses and a sda socket with 2 male pins.
System Details:
Marantz SR 5010, Rega RP1, Marantz CD 5004, Denon DRR-680, Carver M-4.0t
Polk SDA 1C (modified), Definitive Technologies BP-10, Polk Audio CS400i
Nope, You've got a pair of the first SDA 2's. I had a pair just like them I bought new in 1983-84.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
gimpod is right on the money. You have the first series SDA2's, I still have a pair that I updated the crossovers on and replaced the tweeters with the new RD-0194 and love the heck out of them.
I will never sell them. -
What im looking for is a starting point. I think I'm going to keep the SL-1000 tweets for now since soon I'll gave a pair of em on the way, one to replace a cooked one in the left channel and another for a spare, dont wanna butcher the cabinets till i have to. Dont know if the bass is where it should be so im thinking of ordering some hurricane nuts to remount the drivers since i think one of the screws might not be tightening enough on some of the drivers.
What are the biggest bang for the buck upgrades for these speakers is what I guess I'm asking...System Details:
Polk SDA 1C (modified), Definitive Technologies BP-10, Polk Audio CS400i -
The RDO-194 is a straight drop in replacement. You don't have to do anything to the cabinet.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Spot on. This is your best sonic "bang-for-the-buck" investment, and they can be resold for a high percentage of their cost later if for any reason that is necessary.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
Dynamat extreme on the driver baskets and passive will clean up the mids.Best part is, it will cost under 20 bucks.
And lets not forget to spike em.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
