Mythos STS in the house
NotaSuv
NotaSuv Posts: 3,871
edited August 2011 in Speakers
Picked up pair of these a few weeks ago for under 1500 shipped :biggrin::eek:
They arrived in original boxes and in perfect like new shape, running them with my SC-07 and using Audioquest Rocket 88 speaker cables and I couldnt be more happy......these speakers are fantastic in HT and are very musical as well....bass is MORE than enough and I am now selling my Velo SPL 15R sub as its not needed with these speakers.....looking for a matching center and rears as now using a TOTL Mirage center and Polk 500 FXI rears. In 2 channel use these sound as good as speakers costing many $$$$ more. Thanks for your help Dan as these truly are a great speaker................have listened to many others in the Def Tch line but these are heads and shoulders above what I have listened to..............
Post edited by NotaSuv on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited July 2011
  • sandworms
    sandworms Posts: 1,043
    edited July 2011
    jealous : (
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • mantis
    mantis Posts: 17,561
    edited July 2011
    Your very welcome. I always try and share GEMS when I find them. Mythos series speakers from the bottom to the top are uncanny. They WOW you with theater and can bring a tear to your eye with Music. I still own my ST's and I have no plans on getting rid of them. I was shopping around looking at Klipsch and B&W and just for the sheer reason of owning something different was really the underline goal. But in the end I stuck with y Mythos system and I'm completely happy.
    I still run my SC-07 and haven't found a reason to upgrade it until now. The Brand new SC-57 is due out soon and I want to pick one up only for the IP control. If the SC-07 was upgradeble to IP control I would just keep it as it does everything I want it to do and sounds damn close to separates.
    I believe I told you this already but you have a few choices for center channels with the STS.
    1) Mythos 9. It's the perfect match and will sound like one full soundstage with the STS off to the right and left.
    2) Mythos 10. It's matched to the ST's but does work well with the STS as the timbre is exact.
    3)CS-8060HD. It's the new BP series center but it has a timbre just like the Mythos series now. From what I learned they are voiced the same so this is a good choice. I plan on bringing home a CS-8080HD to do a VS battle with the Mythos 10 to see which sounds better with my ST's. According to our DEF TECH rep , this center is amazing as he replaced his 10 with it and loves the hell out of it. I want to give that a shot.
    As for rears it really depends on your room , placement and what you listen to the most. I Honestly believe you should just get Mythos 9's and call it a day. They are the perfect match your STS's and will make for an incredible SACD and DVD AUDIO experience not to mention theater is down right scary with them pulling surround duty.
    I'm very pleased your loving the STS's as I really did a huge shoot out between them and the ST's. They are about 85-90% of the ST's for 1000.00 retail less. I would be just as happy if I purchased them instead of my ST's and with the extra cash I could have purchased other stuff. But the ST's are the king for a very good reason as directly compared have the last word in overall everything.
    Let me know if you need any help calibrating them, they can be a little tricky to get right. I have spend countless hours perfecting the perfect calibration technic's to get them to perform 100%. With a little help and advice from Def Tech as well.
    I'm gonna require some pic's of those babies. Love to see them in your set up. Also sounds like another club we could start in here. ICE DEF TECH.
    Dan
  • NotaSuv
    edited July 2011
    pics up soon....busy with a new job :)
  • NotaSuv
    edited July 2011
    leroyjr1 wrote: »
    Congrats.
    You are one that does know how great these sound :wink:
  • leroyjr1
    edited July 2011
    Dan, I like the CS8080HD much better than the Mythos 10. The problem I had with the 10 is it trying to produce a full range sound and it does a good job but the 8080 sounds much cleaner and the clarity is much better. You can only get so much out of that small of an enclosure.
  • leroyjr1
    edited July 2011
    NotaSuv wrote: »
    :biggrin: I'm running my Mythos ST off my Pioneer Elite sc-27 and didn't like what MCACC did to the top end so I turned the EQ off.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited July 2011
    What did it do lee ?
  • leroyjr1
    edited July 2011
    It made it too bright. I like the sound better running it flat. As Dan said earlier these speakers can be very tricky setting up properly.
  • leroyjr1
    edited July 2011
    mantis wrote: »
    Dan, got any info on the new Pioneer Elite sc-57? I heard they got rid of the ice amp.
  • mantis
    edited July 2011
    leroyjr1 wrote: »
    I have not heard that. I can check I believe I have the spec sheet in my email. Let me go check on that.
    Dan
  • mantis
    edited July 2011
    Ok I can paste some spec's so you can check them out. Class D ICE amps are still there but now have 9 channels.
    CLASS-D3 AMPLIFICATION
    › 140 W x 9 (20Hz – 20 kHz, THD 0.08% @ 8 ohms FTC)
    › 8 & 6 Ohm Impedance Select
    BUILD
    › 3-D Space Frame Construction
    › Aluminum Front Panel
    › Advanced Direct Construction
    › Trans. Stabilizer
    AUDIO FEATURES
    › AIR Studios Monitor Certification
    › THX Ultra 2 Plus
    › Dolby? TrueHD / Dolby Pro Logic? IIz / Dolby Digital EX / Dolby Digital Plus
    › DTS-HD? Master Audio
    › DTS Neo:X - 9.1 Channel Surround
    › Dual TI “Aureus” 32-Bit Digital Core Engine
    › 192 kHz / 32-bit Digital to Analog Converter
    › 192 kHz / 24-bit Analog to Digital Converter
    › Pioneer Advanced MCACC Room Calibration
    HOME NETWORK FEATURES
    › AirPlay
    › DLNA Certified? (1.5)
    › Internet Radio with vTuner
    › PANDORA internet radio
    › Rhapsody? Music Service1
    › Sirius? Internet Radio1
    › Windows? 7 Certified
    › Home Media Gallery
    › FLAC 192 kHz / 24-bit Audio File Playback › WAV 192 kHz / 24-bit Audio File Playback
    CONNECTIVITY
    › Made for iPod?, iPhone?, iPad?
    • Charges iPhone, iPad, iPod
    • Combination USB / Composite Video Cable Supplied
    • iPhone, iPad, iPod Stored and Streaming Audio & Video with Album Art
    › Memory Audio Playback (MP3/WMA/WAV) › Pioneer Air Jam App
    • Connects via Bluetooth? to Share Music and Create Playlists (With iPod touch, iPhone, iPad)
    • Free via the App StoreSM (Optional AS-BT200 Bluetooth Adapter Required) › HDMI Inputs (7 In (6 Back, 1 Front) / 2 Out)
    › Front USB Input
    › Ethernet Terminal
    › Wireless LAN Ready (Optional AS-WL300 Wireless LAN Converter Required)
    › Phono Input
    › Sirius XM Radio Ready2
    › Adapter Port (Optional AS-BT100 or AS-BT200 Bluetooth Adapter Required)
    › Component Video Inputs (3 In / 1 Out)
    › Digital Inputs (2 Coaxial, 3 Optical)
    › Analog A/V Inputs (4 A/V, 1 Audio)
    › 11.2 Assignable Pre-Outs for up to 9.1 Channel Playback
    › 10 Mode Speaker Assignment
    › Large Speaker Terminals (9 Channels Assignable)
    CUSTOM
    › Pioneer iControlAV2 App
    • A/V Receiver and Blu-ray Disc player Control From iPod touch, iPhone, iPad
    › IP Control with Full 2-Way Feedback
    › AVNavigator System Set-Up (CD-ROM Included for PC) › Full Color Graphic User Interface (GUI)
    › Zone 2 AV with HD Component Video Output
    › Zone 3 AV
    › RS-232C
    › 12v Trigger (2 Out)
    › SR In/Out
    › IR (2In / 1 Out)
    › HDMI Standby Through for Low Power Consumption
    › Detachable Power Cord
    › Auto Power Down
    › Illuminated Learning Remote Control
    Precision Distance
    3D Time Axis Measurement
    Polarity Check
    Reverb Before and After Calibration Results (OSD and iPad) Standing Wave Control
    › Pioneer Sound Enhancements
    • Pre-Amp Mode
    • Front, Center, Surround Bi-Amp
    • 32-Bit High Bit Sampling
    • Full Band Phase Control
    • Phase Control Plus
    • Virtual Depth, Height and Surround Back
    • Optimum Surround - Auto Bass, Dialog, and Surround Balancing
    • Jitter Reduction
    • PQLS Bit-stream
    • Auto Sound Retriever (Multi)
    • Sound Retriever AIR
    • Front Wide Surround Movie & Music
    • Auto Level Control (Multi)
    • Advanced Surround (15 Mode DSP)
    • Front Stage Surround
    • Headphone Surround
    VIDEO FEATURES
    › Marvell QdeoTM 1080p/24fps Video Scaler
    › Advanced Video Adjust
    › Stream Smoother
    › Triple HD Noise Reduction
    › Video Conversion to HDMI
    › HDMI? Features
    • 3D Ready (Blu-ray Disc?, Broadcast and Game)
    • Audio Return Channel
    • Deep Color and x.v.ColorTM
    1 Subscription Required. 2Antenna and subscription required and sold separately. Bold denotes step-up features from SC-55
    Dan
  • mantis
    edited July 2011
    True to their name, Pioneer Elite receivers are designed for a very select group of users – those who settle for nothing less than the best in audio and video. The state -of-the-art performance and specifications of these high-end products are the result of uncompromising standards of engineering and manufacturing, painstaking selection of parts and devices, and careful testing of each component. For 2011, this heritage continues with connectivity and control features never before seen in the AV industry.
    Class-D3 Multi-Channel Amplifiers
    Newly re-designed for 2011, the SC-57 and SC-55 are the first to incorporate Pioneer’s 3rd generation of Class-D multi-channel amplifiers; Class-D3.
    The most powerful home theater receivers available today
    Simultaneous Power Output – Class-D3 amplifiers are capable of producing extremely high power output simultaneously to up to 9 channels from the most demanding multi-channel soundtracks with maximum fidel- ity even when the highest volume levels are desired.
    THX Certification – Class-D3 amplifiers continue to be the only multi-channel Class-D amplifiers to achieve THX Ultra 2 Plus certification (SC-57) and THX Select 2 Plus certification (SC-55) to ensure Reference Level sound reproduction in any room, regardless of room size.
    All of the sound quality Blu-ray has to offer
    Since 2007, Pioneer has continued to champion
    Class-D amplification as the only viable amplifier
    solution for uncompressed Dolby? and DTS? multi-
    channel soundtracks available on Blu-ray? disc. With
    lessons learned from the previous two Pioneer Class-D designs, these new Class-D3 amplifiers provide an- other level of quick response dynamics across the widest frequency range with incredible power, precision, and detail.
    AIR Studios Monitor Certification – Both models are sound quality “Mastered” by AIR Studio’s sound engi- neers to ensure certified receivers will faithfully re-create the essence of the original recording as the artist intended.
    Direct-Thru Signal Path – Class-D3 amplifiers benefit from an improved Direct-Thru design with state-of the art circuit mounting techniques allowing for fewer parts and a shorter signal path virtually eliminating “ ringing” without the need for cumbersome feedback-loop filtering.
    A New Era in Custom Integration
    With full integration into the home network , both the SC-55 and SC-57 offer the fastest, most comprehensive 2-Way communication with near instantaneous command and control metadata confirmation. Headers for metadata include; Title, Artist, Album, Genre, Format, Bitrate, and Buffer information on-screen or via iControlAV2 for iPhone?, iPad?, and Android? devices.
    Versatile Amplifier Configuration – Class-D3 amplifiers offer the widest variety of customized amplifier configurations to suite any “whole home” speaker system. Set-up options range from 5.2 speaker ar- rays with the addition of 4 additional channel combinations including surround back, front height, front width, zone-2 and zone 3, bi-amping, as well as B-Speaker.
    DTS Neo:X – Both models offer DTS Neo:X a new soundfield technology that provides up-mixing to 9.1-channels from any source utilizing a combination of front height, front wide, or surround back speaker configurations.
    Integrator Tools – Comprehensive custom installation features including:
    • Full IP Control with 2-way metadata
    • 3 zone AV with On-Screen Display to each zone • 11.2 channel pre-outs
    • Detachable power cords
    • 12v triggers
    • Programmable Auto Power Down for each zone
    • HDMI assignment to Speaker B
    • Zone 2 Component Video Output for HD sources • 7.1 Multi-Channel In (SC-57)
    • IR In/Out
    • RS-232
    Custom Control Partners – Both the SC-55 and SC-57are certified by custom partners Control 4?, Crestron?, AMX?, RTI?, Universal Remote?, and Savant?. Once certified, control modules are created and published to ensure integrators are equipped with a wide choice of advanced control options for IP, Serial, and IR commands.
    Dan
  • mantis
    edited July 2011
    What else I noticed about the SC-57 is the dual sub outs . I so want that to make my life easier to calibrate the ST's. I can do without it , it's fine but the dual outs allow you to leave everything plugged in and calibrate from your chair. Ok call me lazy but I like that feature.
    This receiver will finally take my SC-07 off my hands. It's going to be tuff to let it go , I might just keep it I like it that much.
    Dan
  • mantis
    edited July 2011
    leroyjr1 wrote: »
    I get it with being a powered full range center channel. The Mythos 10 does a killer job when wall mounted. I'll post some pic's of mine wall mounted. It's how it's intended to be installed. In the field I only put one Mythos 10 on a cabinet top and it didn't perform as well. At home I tried it underneath non wall mounted and it worked ok, it sounded a bit thin. But with calibration you can get it to blend in perfectly no matter what. On wall it does have a fuller more natural sound. Check out the pic's
    Dan
  • mantis
    edited July 2011
    leroyjr1 wrote: »
    I'm wondering what happened during MCACC that cut your top end? I'm assuming you have many reflections in your room. Proper placement of the mic makes a huge difference not to mention silence. Any knd of noise throws off the calibration.
    I have also found MCACC usually helps better then all other room calibration systems I have used including YPAO , Audyssey, and ARC from Anthem. Bose room calibration however does a pretty damn good job .
    Dan
    EndersShadow Posts: 17,722
    edited July 2011
    mantis wrote: »
    Does MCACC EQ the sub as well? Asking because looking at recommending a Denon 1611 to my dad over a Pio due to the MultiEQ in the Denon.
  • leroyjr1
    edited July 2011
    No it doesn't EQ the sub.
  • obieone
    obieone Posts: 5,077
    edited July 2011
    I was thinking about selling mine, to reduce some debt, but figured I'd never find another pair for the price I paid.
    And forget about finding anything comparable in this range for SQ. Maybe the new new LSIM's, but eh, I'm too lazy to pack these up.
    If I had to pick one song that makes these speakers REALLY shine, it would be 'Ri Na Cruinne' off of Clannad's Anam album. You can listen to the song at Amazon.
    It was this song that re-sparked an interest in audio, after a year.
  • pearsall001
    pearsall001 Posts: 5,327
    edited July 2011
    NotaSuv wrote: »
    Looks like someone's going to have some fun!!!! Great speakers at an unbelievable price to boot. Congrats & enjoy.
  • mantis
    edited July 2011
    It depends on the level of Pioneer or Elite you are looking at. It does Phase and level.
    Denon does not compare to Pioneer very well IMO. I think Dollar for Dollar Pioneer wins hands down in every single area. Sound quality and dynamic range is where pioneer is superior to Denon. Denon does however offer a nice balance of features which has been their strong point for Decades.
    With the new Pioneer and Elite receivers , they really lead the pack with Airplay , streaming and control. Sound quality is as good as it gets with a receiver. Nothing out there in it's price class is better IMO.
    Dan
    edited July 2011
    mantis wrote: »
    Looking at their sub 300 AVR's so nothing in the Elite line.....
  • NotaSuv
    edited July 2011
    Thanks Phil once I have matching center and rears I will get into some serious calibration but as they all sit now it sounds great to my old aging ears...hope all is well in the Garden State...........
  • mantis
    edited July 2011
    Start around 12 o'clock with the sub level. It's about the right spot in most rooms. Some load at that level so I back it off a tad. Both speakers can be at different levels depending on placement and room boundaries. Currently my left is at 12 o'clock and the right is about 12:30 at I have no side wall for about 12 feet. The left is about 4 feet from the side wall. I'm also about 26 inches to the front of the speaker from the back wall. I can go closer with no Loading problems. They don't load as much as typical subs or speakers. I chalk it up to the cabinet design being round at the back. The Granite bottom really helps get a good load in the room.
    Dan
  • leroyjr1
    edited August 2011
