CRS+'s and mounting Gimpods (Tony's) X-over's
Toolfan66
Toolfan66 Posts: 17,338
edited July 2011 in Vintage Speakers
I have been working on these and have been trying to figure out where to mount them, The best place I can see is on top up by the tweeter this seems to have the most room to mount Tonys boards. I find if I put it to the baseof the cabinet the crossovers are real close to the drivers and passive.
I'm thinking of using velcro to hang them upside down in the the cabinet with the backing board. I really don't want to screw into the upper side of the cabinet.
Has anyone here used Tony's boards in the CRS+'s yet? if so how did you mount yours??
Thanks!!
Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s
Post edited by Toolfan66 on
  • nspindel
    nspindel Posts: 5,343
    edited July 2011
    Not yet, but I'm anxiously awaiting this problem being solved for me. I bought Sal's CRS's which included Tony's boards. Mounting in CRS+ definitely looks like it's going to be interesting. Pics, folks, lots of pics...
    edited July 2011
    I will take pics on how I'm doing mine, I will be picking up some Heavy Duty Velco and I will also use some hot glue. You will need to make a backing board, I made mine out of lexan and ordered some 8-32 nylon standoffs from Mouser. The crossovers look great and these bad boys will be singing by Saturday..
    SVS SB16 X2
  • gimpod
    gimpod Posts: 1,793
    edited July 2011
    Man I wish I had a pair of CRS+'s so I could figure this out. At first I thought "Velcro" no way but then I thought If you glue & staple it to the cab & glue & screw it to the Lexan that should work. Also another idea is to make a offset mounting plate out of Lexan so you could mount the board lengthwise running top to bottom in the original place. If only I had a pair of these.
    edited July 2011
    No worries Tony these will look awesome when I'm done with them. I should be able to post some pics this weekend!!!
    SVS SB16 X2
  • gimpod
    gimpod Posts: 1,793
    edited July 2011
    COOL. :cool: I was just thinking out loud (I know careful I might hurt myself:tongue:). I'm really interested in seeing what you come up with & with you doing it I'm sure it will be well thought out and rock solid.:smile:
  • nspindel
    edited July 2011
    And then I can copy it. Fah la la la la.....
