Best In-Walls to replace LSi?
DVOuSS
DVOuSS Posts: 52
edited July 2011 in Speakers
I am contemplating liquidating my LSi setup since in was moved downstairs to my smaller living room. To replace them I am looking for some good inwalls. Any suggestions? Currently the only replacements I have seen would be the Polks or some from Axiom audio....any help would be appreciated.
Living Room
Toshiba 55" 240HZ LCD
Onkyo TX-NR807
Emotiva XPA-5
HTPC
Polk Audio LSi 25 - Mains
Polk Audio LSiC - Center
Polk Audio LSi 9 - Surrounds
DSW microPRO 4000 x2 - Subs
Media Room
Mitsubishi 73" DLP
Onkyo TX-SR875
HTPC
2 x JBL Urei S300 Amplifiers
2 x JBL Urei S150 Amplifiers
JBL Synthesis Three S3M - Mains
JBL Synthesis Three S3HC - Center
JBL Synthesis Three S3S - Subs
JBL Synthesis Two S2A - Surrounds
Post edited by DVOuSS on
  • ROHfan
    ROHfan Posts: 1,014
    edited July 2011
    I went through a few different rears/front heights and have finally settled on RCi85's as my rears and RCi65's as my front heights. I see no need to upgrade them anymore as they've exceeded my expectations and are quite transparent.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
    tonyb Posts: 33,015
    edited July 2011
    Legacy makes some darn nice in-walls, not cheap though. Check them out.
  • DVOuSS
    DVOuSS Posts: 52
    edited July 2011
    the legacys look awesome and the specs are good, but holy $h*& $3500 for the mains and $1800 for the center? I am sure they're awesome, but they won't be gracing my walls. Thanks for the input.
    Living Room
    Onkyo TX-NR807
    Emotiva XPA-5
    HTPC
    Media Room
    Mitsubishi 73" DLP
    Onkyo TX-SR875
    HTPC
  • DVOuSS
    DVOuSS Posts: 52
    edited July 2011
    The Legacy logo looks familier..is this the same Legacy that made pawn shop level car audio?
    Living Room
    Onkyo TX-NR807
    Emotiva XPA-5
    HTPC
    Media Room
    Mitsubishi 73" DLP
    Onkyo TX-SR875
    HTPC
    tonyb Posts: 33,015
    edited July 2011
    DVOuSS wrote: »
    Dude, look at their offerings,you tell me.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2011
    LCi--RTS series
    RT1
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited July 2011
    Martin logan has a great line of in wall speakers
  • DollarDave
    DollarDave Posts: 2,575
    edited July 2011
    What's your budget?
    I've had good results with both the RC and the TC series from Polk. I haven't invested in their offerings that are farther up the food chain, but I doubt you could go wrong. It all depends on your budget. Bang for your buck is going to be Polk.
  • mantis
    mantis Posts: 17,204
    edited July 2011
    I guess my question is what are they going to be used for? Do you have proper placement for in walls in the room you are planning on?
    I use Definitive Technology and they are an incredible sounding speaker. Their new Line up is just simply amazing. I would absolutely put them up against your LSi line. I believe they are better sounding speakers by far. They are also more explosive and easier to drive.
    I suggest the following setup for a 5 channel theater package to replace your LSI's.
    Left Center and right or LCR http://www.definitivetech.com/Products/products.aspx?path=In-wall/In-Ceiling%20Speakers&productid=UIW%20RLS%20II
    Rears http://www.definitivetech.com/Products/products.aspx?path=Surround%20Speakers&productid=UIW%20RSS%20II
    I have done this very in wall package with excellent results. If you really want to go stealth , check out these subs for in wall use.
    Sub for in wall I suggest buying 2 http://www.definitivetech.com/Products/products.aspx?path=Subwoofers&productid=IWSub%20Reference
    Also pick up the sub amp as they don't work without it. Use high quality speaker wire like 14-2 FLx from Audioquest for everything and it's a go. You will be amazed in their performance.
    Sub amp you only need one http://www.definitivetech.com/Products/products.aspx?productid=SubAmp%20600
    Dan
