RM705 power problem
rameshvikraman
rameshvikraman Posts: 4
edited July 2011 in Troubleshooting
by mistake my RM705 sub woofer is plugged to 220v power point instead of 110v. it is not working. can you help me...is there any fuse inside the cabin...?
Post edited by rameshvikraman on
  • dorokusai
    dorokusai Posts: 25,577
    edited July 2011
    I believe there is a switch on the amplifier(rear) that switches from 110/220. Check that and there is a fuse either mounted as a twist lock button on the rear or you'll have to open up the subwoofer and look inside, on the amplifier board itself.
  • rameshvikraman
    edited July 2011
    thank you dorokusai..... there is no such switch on the amp and no such fuse on rear.
  • dorokusai
    edited July 2011
    Time to get a screwdriver and remove the amp from the box.
