SDA SRS 2 with adcom gfa 7700 problem
joe619
joe619 Posts: 3
edited July 2011 in Vintage Speakers
Hi guys, here is my situation. I just recently bought an SDA SRS 2, adcom gfa 7700 amplifier and onkyo p301 preamp. I properly connected all 3 of them and when i turned it on, i get a loud sound and it do the same thing when i turned it off. When i connect my other speakers klipsch klf 30, it works fine.
Then i used a vintage pioneer sx780 for the sda and it work fine.there was no lose wires or connection i even used a different rca and speaker cable but it still do the same thing. any suggestion on what was the problem.
Thanks,
Joe
Post edited by joe619 on
  • gimpod
    gimpod Posts: 1,793
    edited July 2011
    I believe that adcom is a NON common ground amp. SDA's REQUIRE a common ground amp or an AI-1 IC cable.
  • gdb
    gdb Posts: 6,012
    edited July 2011
    Try disconnecting the cable between the speakers, does it still happen? And welcome to the world of SRS-SDAs,SRS2s are great model to have!
    F1nut Posts: 50,766
    edited July 2011
    Only one speaker? :confused:
  • joe619
    joe619 Posts: 3
    edited July 2011
    gimpod: I believe that adcom is a NON common ground amp. SDA's REQUIRE a common ground amp or an AI-1 IC cable.
    Where exactly can i buy this cable and can you provide a link. Thank you.
  • joe619
    joe619 Posts: 3
    edited July 2011
    A pair of SDA SRS 2 with interconnect cable
  • george daniel
    george daniel Posts: 12,096
    edited July 2011
  • Schurkey
    Schurkey Posts: 2,104
    edited July 2011
    Blade/Blade SRS 2? Yeah, you can MODIFY the speaker to accept an AI-1 cable, but it's an unsatisfactory solution because the sound quality is "off" somewhat.
    Better to TL them (RDO-198 tweeter mod) and use with a common-ground amp.
    PIN/Blade SRS 2? You're all set to add an AI-1 or equivalent (Dreadnaught). See multiple discussions on the impossibility (or not) of using the 198 tweeter.
  • gdb
    gdb Posts: 6,012
    edited July 2011
    Waaaayyyyy simpler to get a different, common ground amp,BTW.:wink:
    F1nut Posts: 50,766
    edited July 2011
    joe619 wrote: »
    Yeah, I figured as much. I was sort of amusing myself, sorry.
    If your serial numbers are 1945 or higher, you can use the AI-1. If not, you'll need to get a common ground amp.
    Polk hasn't sold the AI-1 for many years, so short of finding one for sale, you'll have to build one.
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited July 2011
    Joe,
    As I mentioned in my email to you earlier, your best bet is going to be to call Adcom, confirm you can strap two of the negative terminals on your amp with a piece of speaker wire and use those two channels.
    F1nut Posts: 50,766
    edited July 2011
    Joe,
    Strapping has a less than desirable effect on the sonics.
