Blade/Blade vs Pin/Pin cable
brgman
brgman Posts: 2,859
edited July 2011 in Vintage Speakers
I found a B/B cable i don't need.Is it the same as a pin/blade.I will just cut off the B/B and put RCA's on the ends if the cable is the same.
Anyone sure?
It sure looks the same.
I’M OFFENDED!!!!
Post edited by brgman on
    Tony M Posts: 11,194
    edited July 2011
    I would sell that cable in the forum or off this thread to help one who needs that special type ends and make a Pin cable from some other source.
  • brgman
    brgman Posts: 2,859
    edited July 2011
    maybe i'll do that.the guy i get cables from is slower than molasses in the winter though.
    you may have heard of him.pepster is his name.:eek:
    I’M OFFENDED!!!!
    edited July 2011
    I've seen that name a time or two lately..:biggrin:
  • brgman
    brgman Posts: 2,859
    edited July 2011
    Haven't we all Tony.Haven't we all!
    I’M OFFENDED!!!!
    Toolfan66 Posts: 17,338
    edited July 2011
    As Tony said sell the original cable if you don't need or want it and build or have someone (pepster) build you one. I modded two of my SDA's and use binding post's for my SDA cables. I also have original Polk blade/blade pin/blade and a A1 SDA cables in my goodie box just in case I ever need them, but I do have 4 sets of SDA's as well..
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • brgman
    brgman Posts: 2,859
    edited July 2011
    Did you use RCA or bananas on the ends after installing binding posts?
    I’M OFFENDED!!!!
  • Systems
    Systems Posts: 14,873
    edited July 2011
    brgman wrote: »
    Damn, price went up!:biggrin:
    Testing
    Testing
    Testing
  • Systems
    edited July 2011
    Binding posts:
    I wish you would do this Mike!
    Then it is just a matter of a banana plug on both ends (a good one at that)!
    Plus, you could use HUGE wire (11 ga XLO or 10 ga something else)!
    Testing
    Testing
    Testing
    edited July 2011
    brgman wrote: »
    Bananas!!:wink: On the A1 Dreadnaught I built I use a Banana for the SDA and a Spade for the negitive side.. I will try and post some pics later..
    SVS SB16 X2
  • brgman
    brgman Posts: 2,859
    edited July 2011
    Great.I'd like to see that.
    I’M OFFENDED!!!!
    edited July 2011
    pepster wrote: »
    Binding posts:
    You and gimpod sharing your talents around here have helped keep this place what it is and should be..:cool:
    SVS SB16 X2
  • Systems
    edited July 2011
    Many thanks Tool, but I do not even come close to Gimpod's talent!:biggrin:
    Testing
    Testing
    Testing
    edited July 2011
    pepster wrote: »
    Yep the dude rocks!!!
    SVS SB16 X2
  • gimpod
    gimpod Posts: 1,793
    edited July 2011
    pepster wrote: »
    Thanks guys. (As my head swells to the size of a Mac truck :redface:)
    Larry your rings are no minor little tweak, One of the best ideas around here and well worth the coin.
    brgman wrote: »
    Anyone sure?
    Don't do it, I think the original Blade/blade cables are very hard to come by. I would just modify an RCA cable for right now (there cheap and easy) to get by on. You can make up a really good one later, with banana plugs and 10ga wire.
  • brgman
    brgman Posts: 2,859
    edited July 2011
    Sounds like modifying this cable would be blasphemy so i will see baout selling it to a polkie that really needs an original B/B.
    Thanks for all the great input.
    I’M OFFENDED!!!!
