Need advice on Speaker options and locations
mccarthy814
mccarthy814 Posts: 11
edited July 2011 in Speakers
Hi All,
I am looking for some advice on Speaker placement in my new living room set up. It's not a dedicated theater so, I have some constraints on speaker locations.
I have a few things going on. I just upgraded my receiver to Onkyo TX-NR609 so, I have 7.1 capability now. Depending on best placement options I'll probably need to consider some combination of Ceiling and other surrounds besides the FXi30s
I can not mount the FXi30s to the wall. My wife wants more of a streamlined look in the room.
I considered tucking the FXi30 on stands at eitehr end of the couch but, am not sure where to find stands and if you take a look at the layout that may not be ideal anyway.
Ideally, I'd like to figure out where everything should go in the 7.1 configuration.
I attached the design/measurements and the placement of my VM10s in L/C/R are noted.
If I can figure out how to use the FXis that would be good, but if not I think I will need to consider selling off the extra speakers I have to purchase speakers that will blend in better.
Any feedback would be great.
System:
Sony Blue Ray - BDP-S380
Comcast DVR - DCX3400m
Onkyo AV receiver - TX-NR609
Sony LCD TV - KDL-46V4100
Speakers:
Center: VM10
Front Left: VM10
Front Right: VM10
Subwoofer: Cambridge SoundWorks BassCube 8s
Surrounds: TBD - working on updating since a living room redesign and new receiver addition
Extras:
1 CSi30
1 CS175i
2 RTi38
Pair of FXi30
Onkyo TX-SR600
Post edited by mccarthy814 on
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited July 2011
    Tough room to optimize speaker placement.
    Ideally, put the TV where the long side of the couch is, couch on the wall with the bay window, blackout curtains on the windows, run a 5.1 or a 6.1 setup with the surrounds on stands near the corners of the room to the L and R of the couch, and maybe a rear center high mounted above the bay window.
    If the SO doesn't go for that, pretty much what you said...surrounds on stands at the far ends of the couch, put a RC by the lamp at the corner of the couch near the wall by the narrow doorway.
    Without re-arranging everything, or getting creative with wall mounting speakers I don't see a 7.1 system working well at all...
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • mccarthy814
    edited July 2011
    Yeah. it's tough. I am stuck with the current furniture configuration though. i tried to get it flipped around the other way, but lost that battle.
    One thought I had was to have in ceilings (80F/X-RT or similar) in each of the corners: above the couch (right, Middle, above small doorway and one in the corner above the desk. I see polk has those OWM3 speakers now which I guess could be an option as well.
    Where the FXi30s are big, the only place I can actually put them on stands are at either end of the couch along the long wall. I am not sure how that would sound if you were sitting in the seats closer to the bay window wall though.
    The last option I thought of was additional VM10s, they are smaller but figuring placement so the whole couch gets the surround is still tricky.
    It's a lot to figure out with the room this way.
    System:
    Speakers:
    Center: VM10
    Front Left: VM10
    Front Right: VM10
    Extras:
    1 CSi30
    1 CS175i
    2 RTi38
    Pair of FXi30
    Onkyo TX-SR600
  • Inspector 24
    edited July 2011
    If you can do in ceiling speakers that may allow you to get your 7.1 channels, however I would think that sticking with just two rear surrounds placed at the corners of the couch would still be better as the sound would be coming at you from the sides, and somewhat behind you, rather than from above.
    Perhaps you have another room in the house the SO doesn't care for?
    Up
    Down
  • mccarthy814
    edited July 2011
    bumping this up. see if there are any additional ideas (diff speaker choice, placement around the room etc). Room has to stay in its current configuration
    thanks
    System:
    Speakers:
    Center: VM10
    Front Left: VM10
    Front Right: VM10
    Extras:
    1 CSi30
    1 CS175i
    2 RTi38
    Pair of FXi30
    Onkyo TX-SR600
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    There is nothing optimum about that setup.
    In ceilings are probably your best bet.
    Maybe a surround bar instead of separate speakers. The distance is your biggest factor. Maybe the Surround Bar 50.
  • 27dnast
    27dnast Posts: 255
    edited July 2011
    I was going to suggest the same thing... look at speakers that go in-wall/ceiling for your surrounds. Probably your best bet... I think you're also looking at 5.1 (using the in-wall/ceiling for surrounds) as your best option.
    Secondarily... what about Polk's sound bar and wireless rear surround (http://www.polkaudio.com/homeaudio/fx/).
    Those would make the wife happy... and would cost less than running wire through your walls (unless you are a great handyman!).
  • 20hz
    20hz Posts: 636
    edited July 2011
    Hi All,
    Wow its a lot like my impossible room !
    I could never get a sub to sound good , so I have my tv in the cornor (like yours) my mains are on each side of the tv and my sub behind it in the same cornor , your rear speakers on each side of the couch in the upper cornors .
    My setup sounds great but I get more bass rumbling down the hall but thats okay since it goes past me to go that way .
