SDA Replacement Drivers
renowilliams
I have a question with regard to driver replcements for my sda 1b's. They currently have MW6509 drivers. Is it possible to use MW6501's, MW6510's or MW6511's or is there a substatial difference in these other drivers?
"They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Bluray: Oppo BDP-93
Post edited by renowilliams on
I may be wrong but the 6510 is a pretty darn close match for the 6509. It is also the same driver they used in the 1c's.
The MW 6510 is not a match for the MW 6509, Not even close.
From 4/14/2011These are the only drivers, aside from the RD tweeters, being manufactured to support vintage products, such as, Monitor, RTA and SDA. You should print this as a reference and keep it handy for the values it contains. There are no grill parts, cables, crossovers, plates or anything else available for the older loudspeakers, unless you know the Polk G O D.
1 Driver Type Q BL Compliance DC Resistance Fs
3 MW 6501 1.470 5.96 N 3.250 E - 3N/M 7.750 Ohms 31 Hertz
4 MW 6502 1.970 5.16 N 1.470 E - 3N/M 3.520 Ohms 44 Hertz
5 MW 6503 1.820 5.24 N 3.550 E - 3N/M 6.540 Ohms 29 Hertz
6 MW 6509 2.100 4.57 N 3.540 E - 3N/M 8.970 Ohms 30 Hertz
7 MW 6510 1.390 6.32 N 3.410 E - 3N/M 6.570 Ohms 31 Hertz
8 MW 6511 1.405 4.34 N 3.496 E - 3N/M 3.130 Ohms 29 Hertz
9 MW 6512 1.905 4.99 N 1.588 E - 3N/M 3.466 Ohms 40 Hertz
P.S. Search is your friend.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
I thought I might be wrong. But it looks like Polk still carries the 6509. So he should be good to go.
