Need info Yaqin MC-10L
  • drumminman
    drumminman Posts: 3,396
    edited August 2011
    Here's a source of both info on tubes, and for purchases:
    http://www.audiotubes.com/
    Not affiliated in any way, except that I plan to purchase some 12AU7/ECC82's for my Candela linestage.
    I've read that his reputation is good though.
  • TheH
    TheH Posts: 3
    edited August 2011
    Thanks for the link, but after reading the FAQ on that site I'm still not sure if I need to reset bias when installing the new 6N1P-EV's, I am keeping the stock EL34B Output tubes.
    heiney9 Posts: 25,445
    edited August 2011
    Bias is only for power tubes, you won't set the bias for signal tubes like driver and pre-amp tubes.
    That's not to say you shouldn't rebias the power tubes if you are using a different driver tube, but if the driver tube/pre-amp tubes are similar in gain, etc you won't need to rebias.
  • TheH
    TheH Posts: 3
    edited August 2011
    heiney9 wrote: »
    Go it, Thank you very much!
