center channel wont work!!
stogs
stogs Posts: 14
edited June 2011 in Troubleshooting
I just setup my yamaha rx v363, everything works great except my center channel. I checked all connections and tried all avr settings, still nothing!! What do I do? I don't have a manual for this thing anymore!! Fronts: rti12, center csi5, sub: psw404, rears: rt15. Please help!!!
Fronts: rti12
Center: csi5
Surrounds: rt10
Subwoofer: (2) dsw pro 600 & psw404
Receiver: Ymaha Rxv363 (weak I know!!):cry:
Post edited by stogs on
  • apphd
    apphd Posts: 1,514
    edited June 2011
    Stogs,
    Switch your center speaker and one of the surround speakers at the terminals of the AVR, this will let you know if you are looking at a speaker problem or something with the AVR. If the problem stays with the center output of the AVR, you can try looking at the number of speakers in the menu. I think you need to select 3 or 5 for the center to be active. Also can look at the center width parameters it may be sending the majority of the signal to your mains.
    Here's a link to a manual. Good luck
    RX-V 363 manual
  • stogs
    stogs Posts: 14
    edited June 2011
    Thanks!! I got it, I had the avr switched to mains and not center. Thanks again!
    Fronts: rti12
    Center: csi5
    Surrounds: rt10
