RM101 - Fixing tweeter?
Shike
Shike Posts: 12
edited June 2011 in Troubleshooting
Greetings,
I contacted Polk support regarding replacement tweeters. Opening the speakers I noticed that the tweeter is glued in. Is there any recommendations for best removing the tweeter? Also, in the email I received they said the replacement tweeter is RD0524-1 . . . the one listed in the unit is RD6524-1. Is RD0524-1 a valid replacement or was the 0 a typo?
Thanks for your time. :smile:
Post edited by Shike on
  • Shike
    Shike Posts: 12
    edited June 2011
    I solved the issue . . . err, sort of. Found out the tweeter front assemble is one piece the hard way. Ordered a new one though, so everything is good. :cool:
