SDA-SRS 1.2tl Crossover Points
xoaphexox
Does anyone know the crossover points (frequencies) of the SDA-SRS 1.2tl?
I am interested in doing some A/B comparisons with different polyswitch replacement resistance values and would like to know which frequency range I need to tweak to only boost/cut the tweets.
e.g. Treble crossover @ 3khz or somesuch...
Thanks!
Thanks!
Burson HA-160D > Adcom GFA-5802 > Polk SDA-SRS 1.2tl w/ Mye Sound Spikes, Mills/Sonicap XO, Larry's Rings, Dynamat Extreme, Cardas CCGR Binding Posts and Jumpers, Custom 10ga interconnect, Custom Gaskets, RDO-198
Post edited by xoaphexox on
None of the literature I have lists crossover frequencies for any of the "TL" series speakers. The specs for the 1.2TL list:
Frequency Response: 10 Hz to 26,000 Hz
-3 dB Frequency Limits: 27 Hz to 25,000 Hz
The SL3000 technical paper says that the lower frequency limit of the tweeter is 1500 Hz.Proud and loyal citizen of the Digital Domain and Solid State Country! -
Good enough for me, I will use 1500Hz as my starting point.
Cheers!
