Worried about my dog Buddy...
VR3
When I got my dog Buddy he had a really bad infection on his right front leg... which healed and went away with alot of TLC!
Well - today - and probably started happening a few days ago - he has a lump in that same spot...
There is a spot that potentially could be a bite - but it is very small...
His demeanor has not changed and is still playful --
Thoughts?
I was going to give it a few days and if it did not decrease in size take him to the vet
Thoughts?
Post edited by VR3 on
If I press semi hard it seems to bother him.. if I just "tap it" he seems indifferent- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
When in doubt, we always take our dogs to the vet. That 50 bucks for the visit is worth the peace of mind.2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
If you got the money I would take him in. Dogs are the best pets. I wish I had taken my dog before his lump that mysteriously showed up and got all weird. To this day, I have not found a good dog to replace him.Fronts: Monitor 20s
Center: CS2
Rear: Monitor 30s
Sub: PSW505
AVR: Pioneer VSX-521K
My first true audio setup
Current Upgrade Plans
Fronts: Monitor 70s
Center: CS2
Rear: Monitor 50s
Sub: PSW505
AVR: ???? No idea yet -
Yeah I plan to take him Tuesday if there is no sign of improvement- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Good luck with your dog.Fronts: Monitor 20s
Center: CS2
Rear: Monitor 30s
Sub: PSW505
Fronts: Monitor 70s
Center: CS2
Rear: Monitor 50s
Sub: PSW505
I hope your dog knows left from right better than you do....
get him checked out, just to be safe.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Dennis Gardner wrote: »I hope your dog knows left from right better than you do....
That's funny.Political Correctness'.........defined
President of Club Polk -
What caused the initial infection? Was it a cut or puncture wound? Might be debris or a foreign object that the skin healed over and is now causing the infection and swelling underneath the skin. If it was a bite you can try childrens benedryl or an antihistamine. I would start with half a pill and go from there. I have also had good luck with first aid anti-biotic sprays, soak the area and a piece of gauze that you can wrap around the site. Use a non-constricting bandage, the best way to apply is to pull out enough slack to wrap around the area once and after every wrap, pull the slack out away from the limb, using your hand to avoid pulling on the actual bandage around the limb and then run the slack around the limb again. Or keep your pinkie finger under the bandage and remove it after you wrap it, but that might be too loose and your dog will just entertain himself with unwrapping it. Tumors and growths are firm to the touch, if it is just swollen or puss it should have some give. Either way, I would take him to the vet first thing.
Vr3MxStyler2k3 wrote: »Yeah I plan to take him Tuesday if there is no sign of improvement
Buddy needs that! while we all hurt, alot of dogs I've had barely make a whimper when you touch a sore spot ... X-rays may be needed, or blood work...:eek: , costs money but worth it
XXX000's to Buddy!!!Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's -
BENADRYL, if it's a insect bite.engtaz
I agree with stuwee- dogs are notorious for being able to tolerate, and hide, extreme amounts of pain. Dogs will yelp when they're surprised/initially hurt, but chronic or constant pain in a dog is typically almost invisible.
Doesn't look too bad from the pictures, and the location is relatively not concerning (leg >>> abdomen/neck/head). Also, if demeanor is the same, and he's still playful, drinking, and eating, probably even less concerning. That said, it's probably worth the 50 bucks for peace of mind if it's not gone by the appointment time...
Good luck, and hope all turns out well. I was close to taking my dog to the vet two days ago for a big lump that appeared on her nose, but it went down in a few hours so probably was just a bite. Bad part about dogs is they never learn! She probably got stung trying to pick up a scent in the long grass off the trail I take her on....which has literally happened 15 times in the two years I've had her! -
Why are you asking this group of audio asshats? TAKE THE DOG IN.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Seriously? I have a lump on my throat do you guys think it is something?
Dude take your dog to a vet. Asking an internet forum about animal care is ridiculous. -
Sounds like his body is forming a cyst over the infection. Have a vet check it out.
Good luck. -
go to the vet. my wife is an LVT and that's the first thing she said. animals don't show the same pain response as humans so that they don't appear weaker or easier prey. (yes even domestic animals)
sounds like his immune system didn't completely fend off infection...went thru the same deal w my cat...time for a vet visit. GL!
mike -
He is at the vet - thanks guys!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Good. I was about to say "take him to the damn vet already!". I learned from my vet that most animals tolerate pain a lot better than we do. So something that would have one of us crying for mommy doesn't phase a dog, cat, etc. Hope he gets better soon.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: Aural Thrills
Digital: Pioneer DV-79ai
Pre: Conrad Johnson ET3 SE
Amp: Conrad Johnson Evolution 2000
Speakers: SDA 2.3TL, heavily modified -
I hope your Buddy is o.k., better to find out early its nothing than wait and lose a leg. Take care of your friend and yourself. Dan
Possibly a Brown Recluse bite? They can lay a serious hurt on dogs (and humans).Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Do you have a sharp utility knife ? Maybe if you just..........:eek: Nah, take him to see the vet.I Hope it's nothing !
Hope he is ok.
Any word, Hope he is OK....
Prayers -
Hope he's fine. Dogs are better tham most if not all people."The door is open but the ride ain't free"
You're the perfect person to help him through it, he'll be fine.
We have 4 dogs when it comes to check ups and heart worm pills and surprise vet visits it can get pretty pricey, we take them in regardless peace of mind is better than hoping it gets better I always restrain from buying new tunes for a while to make up for the vet bills. You made the right decision and brought him in, hope all is well, now just refrain from buying new tunes and audio gear to recoup those vet bills.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
Vet.
That "brown recluse" thing that Steveinaz mentioned wouldn't be anything to futz with. A number of other things are time sensitive, too, so ......
Vet.Sal Palooza -
Well???? What did the vet say?Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
The vet just gave me some medicine to reduce the swelling. It seems to have gone down a little bit - but he says if it is not down soon we need to get a bit more serious...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Vr3MxStyler2k3 wrote: »The vet just gave me some medicine to reduce the swelling. It seems to have gone down a little bit - but he says if it is not down soon we need to get a bit more serious...
Any indication of cause ...good luck to buddy2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
