Boy am I ever PISSED!
gimpod
gimpod Posts: 1,793
edited June 2011 in The Clubhouse
I had a water heater blow while I was away that didn't get fixed right away so now I've got mold and water damage everywhere and it just keeps getting worse everyday. Just discovered that It got into my storage room, my original box's for my 1C's, a S.A.E. pre-amp (might be able to save this one), a pair of noname speakers and a whole bunch of other stuff that's all wet and moldy and probably getting tossed. So now I have to move ASAP! and this is no easy thing seeing how I'm in a wheelchair. Man this is turning into a real headache thank god I don't own a gun because you'd probably hear about it on CNN.
Sorry just had to vent.
Post edited by gimpod on
  • aviator
    aviator Posts: 159
    edited June 2011
    Damn! Sorry to hear of your bad luck.
  • george daniel
    george daniel Posts: 12,096
    edited June 2011
    ouch-- hope you are able to recoover your stuff.
  • dorokusai
    dorokusai Posts: 25,577
    edited June 2011
    Mold is a PITA to get rid of. You better start tearing stuff down now and getting a dehumidifier running 24/7. Get a hold of the problem quick and get a water heater sink or overflow pipe connected if you have to replace it. This will eliminate future issues.
  • gdb
    gdb Posts: 6,012
    edited June 2011
    That sucks! I hope you have good insurance coverage.
  • stuwee
    stuwee Posts: 1,508
    edited June 2011
    dorokusai wrote: »
    Mold is a PITA to get rid of. You better start tearing stuff down now and getting a dehumidifier running 24/7. Get a hold of the problem quick.
    Good advice!! Get someone to help you out, try to stay calm, good luck to ya, take care.
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • mrbigbluelight
    mrbigbluelight Posts: 9,897
    edited June 2011
    Sorry to hear of your misfortune, Gimpod, but it may not be quite as bad as what it appears to be.
    The stuff that's wet and moldy can be reclaimed/restored. Even electronics.
    Stuff that you're sure may fall into the "WTF !" category can, at the hands of a good disaster recovery company, be returned to a "WOW !" condition.
    I've had personal experience with "ServPro" (Twice :frown:) and have had VERY satisfactory results.
    Mold can be remediated.
    No shortcuts there, to be sure.
    Carpet/pad gets ripped up and removed.
    Drywall gets ripped out to the studs, bleach/anti-goober stuff gets sprayed, and the problem goes away permanently.
    IF DONE CORRECTLY. No shortcuts.
    Don't know if you're covered by insurance; that'd make life a lot easier, of course.
    If you're having to move due to the mold and you're renting, your landlord may have to provide lodging until the mold is remediated.
    The Red Cross will/may pick up the tab for 3-5 days; enough time to get stuff figured out. Plus they have a lot of resources/referrals at hand to point you in the right direction.
    In the mean time, vent away ! Better out than holding it in. And keep pluggin' and chuggin'; it gets better.
  • cfrizz
    cfrizz Posts: 13,415
    edited June 2011
    Sorry this has happened. Wish you the best of luck getting everything taken care of.
  • codyc1ark
    codyc1ark Posts: 2,532
    edited June 2011
    Sorry to hear that, honestly if I was near, I'd try and make a day to help a fellow polkie out. Good luck!
  • Fireman32
    Fireman32 Posts: 4,845
    edited June 2011
    So sorry to hear man. I hope you can save everything
  • danz1906
    danz1906 Posts: 5,144
    edited June 2011
    Sorry to hear of your misfortune,I hope that everything works out.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    tonyb Posts: 33,029
    edited June 2011
    Good advice from the big blue. Also, when water heaters go, it's usually from rust at the bottom. No overflow valve will compensate for a water heater that cracks on the bottom. The best advice is if your gone for extended periods,to just shut it down, unless it's the winter of coarse, then just turn it down.
    Mold can be removed and finding a contractor to do it right may take some legwork. Hopefully your renting, because if you own the joint, when it comes time to sell,you'd have to disclose any mold conditions and the company who took care of it. Needless to say, not appealing to a buyer.
    Had one go on me while I was gone a few days, luckily I have a floor drain and all the water stayed within that room on the floor. Don't know what it is about water heaters, they always tend to take a dump when your gone. Never when your home watching the tube. Hopefully insurance will cover most of this for you, good luck with it all and we all hope things work for the best for ya.
  • gimpod
    gimpod Posts: 1,793
    edited June 2011
    tonyb wrote: »
    Ain't that the truth, This is the first time it's ever happened to me. I've had them replaced because they weren't getting hot but never a leak funny thing is this one is only about 5-6 years old.
    Unfortunately it's an apartment and I don't think they would like it if I got some people in here to rip out the carpeting and drywall. Not a bad idea also being in a chair and needing a special kind of bed puts any temporary lodging options at zero. So I'm stuck here until I can get another place by next weekend I hope or see if I can get in the VA for a bit (I just might have to do that).
    Thanks for the support and ideas guys it helps.
    EndersShadow Posts: 17,596
    edited June 2011
    Damp Rid to the max. It will help get rid of the smell, and pull the humidity out of the air....
    Hopefully it all works out. Hate to see it happen to a fellow Polkie :frown:
  • mrbigbluelight
    edited June 2011
    Gimpod, happened to notice that your location is "The Pacific Northwest".
    If I'm not mistaken, that's kind of close to ...... well ..... Canada.
    Assume you'll have an insurance adjuster out Monday, so you might want to have him check for evidence of foul play.
    You might find that you're a victim of certain "foreigners" who are well known for mischief making. Who scoff at the concepts of international borders. Who think nothing of spreading their particular brands of foofooraw and kerfuffle to innocents everywhere, mocking all norms of accepted civilized behavior !! :eek:
    .... although it could just be a case of broken water heater after all.
    But be careful in the meantime ! Those hooligans are very wiley !
  • gimpod
    gimpod Posts: 1,793
    edited June 2011
    Yep it must have been those damn "foreigners" :wink::biggrin::biggrin:LOL:biggrin::biggrin:
  • 20hz
    20hz Posts: 636
    edited June 2011
    sorry to hear about it gimpod .
    are you permanantly disabled ?
    friends and family will help you get through this situation , a couple weeks ago I broke my leg sometimes I stay in bed all day full of pain pills, if it wasent for my wife it would be VERY difficult to be healing .
  • headrott
    headrott Posts: 5,496
    edited June 2011
    Sorry to hear Tony. I hope you can save most of your equipment. If you absolutely need some help, I may be able to drive up to help you move. It would have to be on a tuesday or wednsday though as those are my days off. Unless another Polkie closer to you can help out (as well)? Let me know if you need help and I'll see what I can do time wise.
    Greg
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited June 2011
    Sorry about your troubles. I almost lost a brand new drum kit because of a water heater that went. I swore that it would never happen again, so I shopped around and went with a tankless water heater. My only regret was not doing it sooner. The internals are all copper, so rotting through is not possible.
    Something to keep in mind for the future.
  • cambir
    cambir Posts: 1,046
    edited June 2011
    Sorry to hear about the water issues gimpod. Hope all goes well and your stuff can be salvaged. Put a call out to us locals if you do need anything.
  • gimpod
    gimpod Posts: 1,793
    edited June 2011
    headrott wrote: »
    Greg
    Greg that's a VERY generous offer but that's just to far of a drive for you. It is greatly appreciated and the just offer alone makes me feel better.
    cambir wrote: »
    Not a bad idea but I don't know for sure where or when I'll be moving, I think it's only going to be 2 apartments over in the same building, wont find out till tomorrow. At this point I think I'm just going to hire a local mover my brother has used a couple times to come in and pack and move me, I think this would be the quickest and easiest way to do it.
    Thanks guys for all your support, It really does help and is greatly appreciated.
    edited June 2011
    gimpod wrote: »
    Your renters should cover the cost of movers and your gears.....after you pay your deductible, but since mine is like 500 that's prob less than the cost of replacing that gear, movers, ect....
    Provided you have renters.
    Best 11 dollars a month I ever spent :smile:
