Powered sub for surround channels?
mdaudioguy
mdaudioguy Posts: 5,165
edited June 2011 in Speakers
While perusing the Polk University pages, I came upon what seems to be a rather unorthodox suggestion, at least in terms of how HT systems are configured and marketed today:
If you really want to push the performance envelope, add a powered subwoofer to the surround channels!
There are lots of indicators on these pages that would suggest they haven't been updated in some time, including the sentence preceding the one above:
A very popular choice for surround channel use is the RTi28.
So, while I doubt many people are currently choosing RTi28s for their new systems, I was wondering if anyone here had tried using a powered sub with their surround channels...?
Post edited by mdaudioguy on
  • mantis
    mantis Posts: 17,378
    edited June 2011
    In order to fully understand the goal , one must embark on the full Home theater journey. Learn what the goal is and tell you if using a powered sub for surrounds is the way to go.
    Dan
  • 27dnast
    27dnast Posts: 255
    edited June 2011
    Mr. Miagi? Is that you?
  • mdaudioguy
    edited June 2011
    Or, if run through The Yoda-Speak Generator...:rolleyes:
    To fully understand the goal in order, embark on the full home theater journey, one must. The way to go, learn what the goal is and tell you if using a powered sub for surrounds is. Yes, hmmm.
  • aboroth00
    aboroth00 Posts: 1,106
    edited June 2011
    I redirect the bass from the surround channels to the LFE subs if that counts.
    2Ch Tube Audio Convert
  • TNRabbit
    TNRabbit Posts: 2,168
    edited June 2011
    You mean EVERYONE isn't running a 7.7 system?!?!??
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • 27dnast
    27dnast Posts: 255
    edited June 2011
    I have a 7.3 set-up at the moment, but will be abandoning that as new equipment is coming in...
    Using the RM6750 series, I have an AVR doing Bass management sending all sound 80hz and below to an Energy sub via LFE.
    Both the center channel and the L/R fronts are wired speaker level to two subs... these two subs are PSW10's. I set the x-over on the backs of each sub to best accommodate a range between 80Hz and up.... with the upper echelon being when the sound from the sub began being directional.
    It was cheap quick fix to boost my system... the sub that came with the RM6750 just wasn't doing the job.
    Truthfully, the real problem is that the RM6750 system is good but I needed something bigger.
    In the end, it worked pretty well. It was a little muddy... but gave the front channels some depth that they were missing....
