What SDA's are these??
halo71
Never seen these before.
--Gary--
Post edited by halo71 on
Wow, that's a pair for the museum..
I bet they sound good also.Most people just listen to music and watch movies. I EXPERIENCE them. -
It has a ported tube as well, I would like to know the facts behind them. has to be a prototype,,Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
Very early SDA2....they usually have a brass plate covering the "port" that had something like signature edition stamped on it. I don't know a lot about them but the driver configuration can vary quite a bit in this series.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Why would they put in a ported hole then cover it with a brass plate??Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
What a cute looking speaker cable feeding them...LOL
Just kidding, how do they sound??
[The Ever-Evolving System
LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD. -
See something new everyday!
I'd keep those cats away from your grills!
Very interesting SDAs. -
Wow!! those are even older than my SDA2's. What the heck is with the tweeters being stacked. That's a new one for me.
These belong to a member at AK. He bought them for $40. I was intrigued by them, thought I would ask here.
12 ohm??
--Gary--
TOOLFORLIFEFAN wrote: »Why would they put in a ported hole then cover it with a brass plate??
Because it wasn't needed anymore. The early models with the brass plate covering the hole were called "Signature Edition".
I have never seen an SDA with the tweeters on top of each other and offset in that manor. But as Doro saaid, there was a lot of variation in the original SDA models, as they were tweaking the design. I'd almost bet some type of prototype that probably very few exsist.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
well played for 40frogskins
First thing crossing my mind:
Not a prototype, just an owner-designed kludge fitted into an otherwise-ordinary speaker cabinet.
Similar to all the folks who replace the passive radiator with some screwy active driver.
I suppose someone at Polk could provide details on prototype/experimental speakers. -
I keep looking at them an thinking they can't sound good set up that way. Mid Driver next to the tweeters that are stacked probably dimensional under the stereo. I don't know what to think anymore.
They are like Polk's own version of Frankenpolk's. -
They sure modified a lot of space and it looks pretty good for a mod. That cabinet is shorter than a typical 2A cabinet with 3 drivers. Atleast it appears to be shorter in the photo, which can be decieving.
Maybe a modification of a pair of RTA 12's, the early RTA12's with the shorter cabinet. Those are not typical SDA2 or 2A cabinets, they are too short. Even if you moved the left driver up where the tweets are now, there's no room to mount the tweets. It seems the PR is mounted higher in the baffle than most pics I see of original SDA 2 and 2A's. That's why I'm thinking the short RTA12 cabinet.
Could very well be a one off Polk prototype SDA.
I think they are about the same size just the placements of the tweeters, drivers and PR are weird.
Here is a pic for comparison.
Look how high up the PR is in the Op's photo, also no matter how you rearrange the drivers in the Op's photo there is no room for the tweets in the trad. side by side config.
Easy way to find out is to check and see if they have SDA interconnect terminals. -
audiocr381ve wrote: »Easy way to find out is to check and see if they have SDA interconnect terminals.
Which they would if they are as I strongly suspect. A one off Polk prototype SDA2 of some sort.
But, yes if they don't have the SDA terminals then perhaps it's a creation by a hack. But I really don't see how they could have modfied it like they did and still make it look unmolested. Unless someone is very good with wood/vinyl/particle board repair, or photo shop, etc
Look at joe08867's photo he posted of SDA 2A's. Someone tell me how you can manipulate those drivers to get the same config as the Op's photo without doing extensive fill work to cover up gaping holes."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul!
There is no way without totally rebuilding the baffle.
They do have the IC.
I would also assume these are not "one offs" as Mark alluded to the fact that they are very early SDA2's. And I have seen other pics and it mentioned before here at CP about the little port that had the brass cover. I would also assume these early ones sound like **** since apparently Polk changed the driver layout early on.
btw....they are 39 1/2" tall.--Gary--
I sent an email to Engineering to ask about some more particulars. Keep in mind that there were a handful of baffles made for the SDA2 around this time, including the "Signature" model that included the brass plate and port. There's no need to try and visually figure out how they constructed one array or the other as this was an experiemental time for Polk Audio. There are a bunch of one-off models, short runs and oddities during the SDA years that still exist but most prototypes were destroyed much as they are today.
Unless someone from Polk snagged them up or they were given to someone as a courtesy, they usually ended up in a dumpster. I've seen dozens of cool prototypes and one off models in my short time here get sledgehammered and busted up for the dumpster. A few were alledgedly saved but we'll never really know their true fate huh? :biggrin:CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Damn how cool would it be to see those before they get crushed!:biggrin: Mark, did you notice the pic above....12 ohms?
Anyway here are a few more pics of the innards....:biggrin:
--Gary--
Halo - Yes, that's odd indeed and I asked about that as well. It's very unique to say the least. I've never seen a pair aside from these and only ran across a couple pairs of the brass plaque models. I had a chance to buy a pair but passed since they were physically a complete mess and needed too much work. I took a pic and posted it here...somewhere.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
The defining feature to these is not the port, but the stacked and offset tweeters. Goes against common SDA theory. I'm still guessing one off prototype.
H9 -
If I were a betting man I would agree,those baffles look to be factory routed for that driver positioning,not an after thought by a would be modder.
They certainly are interesting looking. Probably don't sound that great if they are wired like a typical SDA. Perhaps they are wired differently.
I wonder which is the left one and which is the right one?"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul!
I bet they sound better than Blose.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
