RTi for Def Tech Mythos?
Dannieboiz
Dannieboiz Posts: 242
edited May 2011 in Speakers
been thinking about going smaller since we moved into a place that has a smaller family room. Does anyone have experience or hard the RTi side by side with the Def tech mythos
I have RTi10, FXi5, CSi5 that I'm thinking of switching out for some Mythos Five, Six and Seven. I have a Velodyne DPS-12 that I'm using with the RTi and will be keeping it with the new setup. I want to go smaller in size but not smaller in sound
Sammy UN55C6400
Onkyo TX-SR875
Def Tech: Mythos One, Three, Six
Velodyne DPS-12
MartinLogan Dynamo 10
Post edited by Dannieboiz on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2011
    I've never heard the Mythos 5,6, or 7's but I've owned the RTI a5,7,9's and Mythos ST towers, & 10's. I do like the tweets on the Def Techs a lot better. They sit right in between the bright rti's and the laid back LSI's. Also they seem to be much more musical than the rti's and with a decent sub can rock for HT. I'd say get your ears on them then decide.
  • mantis
    mantis Posts: 17,561
    edited May 2011
    I never did a side by side with the Rti's and Mythos series but I have a tone of experience with both.
    As Leroyr1 said, they are way more musical and detailed over the Rti line. The Mythos line is in another class. They are the perfect double duty speaker being very musical and crazy theater like.
    If you decide to go with the Mythos line from Rti , your in for a treat. Everything you like about the Rti line will be there but improved in every way.
    No smaller sound with the Mythos line. I suggest checking out the Mythos STS and get rid of the floor sub as well. This will give you a small foot print and 2 subs. Mythos 9 center channel and a pair of Gem's for the surrounds and your done.
    Dan
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited May 2011
    I agree with the others. The RTi's are definitely good speakers but the Mythos are incredible. Warm, detailed and very musical.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • Dannieboiz
    edited May 2011
    Wow, my RTi speakers are pretty much the biggest of what I can get in this Polk series and you're saying that the Mythos are generally better overall? I think I'm gonna jump in with both feet on this one. Small front print + better sound = perfect.
    Sammy UN55C6400
    Onkyo TX-SR875
    Velodyne DPS-12
