Onkyo 1008 & Crown,Behringer,or Emo
S T R Y K K E R
I'm debating if I should just do the mains & let the Onkyo do the rest of my system.......
Crown XLS1500,Or Behringer EP4000.seem to be enough power and are 1/2 the price of the XPA-3......
I can get either both the Crown & Brhringer for under $275.00 shipped...be here by this Wednesday......
Will having the 1008 do the center and other amp doing mains make differents in sound.dont want it to sound awful
16' x 12' Man Cave
Onkyo TX-NR1008 9.2 AVR
Polk Monitor 70's--Mains
Polk Monitor CS2--Center
Polk Monitor 30's--L/R Height's & L/R Wide's
Polk Monitor 30's--L/R Side Surround
Polk Monitor 30's--L/R Back Surround
(3)BIC Formula-12--Sub's
(4)Aura Pro Bass Shakers with Crown XLS 1000 amp
Emotiva-XPA-3 AMP for L/C/R
Epson 8100--1080p LCD projector
120" Elite Screen-- High Contrast Gray
Sony BDP-CX960--400 disc BLURAY player
Sony DVP-CX995--400 disc DVD player
XBOX 360 & PS3
XBOX 360 & PS3
Post edited by S T R Y K K E R on
I use an 808 and have a sunfire for the 2 channel.it works fine unless you need to drive the center and rears at extremely high levels.
added a parasound 2100 with a HT bypass and my HT and 2 channel is just a button push apart.Works great! don't need to switch wires around or have a seperate 2 channel rig to run my music.Good luck.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
brgman.............I have absolutely NO interest in music at all.............this system is for Bluray & Gaming ONLY!
Do I even need an amp with my Onkyo?
I just want the best sound from the mains thats all.16' x 12' Man Cave
XBOX 360 & PS3 -
S T R Y K K E R wrote: »brgman.............I have absolutely NO interest in music at all.............this system is for Bluray & Gaming ONLY!
How many times do you need to read it in different threads?
http://www.polkaudio.com/forums/showpost.php?p=1573844&postcount=2Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Cables: AudioQuest McKenzie XLR's/CDP/Amp, Carbon 48/BRP, Forest 48/Display, 2 channel speaker cable: Furutech FS Alpha 36 12AWG PCOCC Single Crystal (Douglas Connection)
When I was young, I was Superman but now that old age has gotten the best of me I'm only Batman -
S T R Y K K E R wrote: »I just want the best sound from the mains thats all.
You are not gonna get it with those amps you list. IMHO of course. Used an option?--Gary--
Agreed with Halo.... you are better served running the reciever and forgetting an amp, given the choices at hand.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
After the last two posts, it would appear that you're shooting for the XPA.Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Just went into settings on the onkyo 1008........
I have to chose either 4ohm or 6ohm.....thats all its allowing me to chose..is this good for my speakers? I could have swore their was a 8ohm setting but its just not there to select!16' x 12' Man Cave
XBOX 360 & PS3 -
Of course used is an option.......just dont have enough cash got about $400 as of now......
I can't find the XPA-3 anywhere.other than the Emotiva site.
Would you guys give me a list of 3 channel amps...(with atleast 200 watts per channel)...thats around 400 to 500.16' x 12' Man Cave
XBOX 360 & PS3 -
S T R Y K K E R wrote: »Just went into settings on the onkyo 1008........
Maybe you're just not reading my posts because I answered this for you once already. So, without further delay, your settings are; 4ohm or 6-16ohm. Naturally, 8 falls in between 6 and 16 so if you select the 6-16 setting on your receiver, your 8ohm speakers will be just fine.Source: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
Maybe you're just not reading my posts because I answered this for you once already. So, without further delay, your settings are; 4ohm or 6-16ohm. Naturally, 8 falls in between 6 and 16 so if you select the 6-16 setting on your receiver, your 8ohm speakers will be just fine.[/
Cool.........you would think that it would have 4 or 6-16........ instead of 4 or 6.16' x 12' Man Cave
XBOX 360 & PS3 -
In that case, get the Behringer or better yet, pick up something from Wallymart.Political Correctness'.........defined
President of Club Polk -
With the speaker package you own , the Onkyo for movies and gaming will be just fine. There is no need to buy amps. Your room isn't that big which doesn't require more then the Onkyo will put out.
Save your money and buy more software.Dan
Thats what i was thinking Mantis......16' x 12' Man Cave
XBOX 360 & PS3 -
I wasn't able to find where the OP mentioned the size area he was working with except that he'd be making 40' runs.
The 1008, if I'm not mistaken is making around 45wpc with 7 channels driven, the OP is planning on running a 9.1(2).
The OP also mentioned that he wants the best sound from his mains. With nine channels driven and no external amp, I don't think he's going to get the best sound from his mains IMHO.
I don't know how accurate this test is, but for your viewing; http://www.soundandvisionmag.com/content/onkyo-tx-nr1008-av-receiverSource: BRP Panasonic UB9000, CDP Emotiva ERC3 - Display: LG OLED EVO 83 C3 - Pre/Pro: Marantz 8802A - Amplification: Emotiva XPA-DR3, XPA-2 x 2, XPA-6, Speakers, Mains/2ch-Focal Kanta No2's, C-LSiM706, S-702F/X, RS-RTiA9's, WS-RTiA9's, FH-RTiA3's, Subs - Epik Empire x 2
WOW thanks Geoff..HOLY CRAP.....45watts at 7.1...HELL THAT MEANS THERES PROBLEY ONLY 30 WATTS AT 9.1.....RIGHT?
IT SEEMS TO BE LOUDER THAN 30 WATTS PER CHANNEL TO ME AT 9.1 THOUGH...
WOW JUST WOW.......the test do not lie though........looks like an amp is INDEED necessary!16' x 12' Man Cave
XBOX 360 & PS3 -
I dont know what your room dimensions are but I just had this exact conversation with someone from my work that doesn't know much about home theatre.
I can speak from my experiences going from a quite capable receiver to the same receiver with an amp. The difference was what I would call a "marked improvement" in overall sound quality, especially from the surround speakers. Stated differently, I think I gained more in the home theatre side of things than music - but both benefit. And lets be frank, a speaker that needs to be good for HT needs to be good with music too, right? After all, music is integral to many movies.
Was the "marked improvement" worth the money I paid? It was for me, but to each their own. I'm not sure I would pay much more than I did - less than $1k, but others would and thats the personal choice we all make in this hobby.
By the way, the amp made the one game I tested sound better too. Again, the amplification of the surround channels made all the difference.Do you hear that buzzing noise? -
16x12 room.
Only want to do mains l/r with amp...
and let the onkyo 1008 do the rest of the speakers.16' x 12' Man Cave
XBOX 360 & PS3 -
Or just a simple 5.1 system. More does not mean better.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Why only amplify the main L/R? I don't get the point in his case if he isn't doing any music. Amplifying the mains generally is done for music, because you only use the main L/R.
In surround 90% of your sound is coming from the center channel, not the mains. You won't gain anything for games/movies by only amplifying the main L/R.
Go all the way (all channels) or go home.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
You do realize that, most of the time, your surround soundtrack isn't anywhere near 30 watts to all channels, right?
In a room that small, the Onkyo is sufficient for HT with your speaker set...unless you want to knock plaster and moldings off your wall? Oh wait, you could run your subs 'hot' and do that.
For music, yeah, I'd amp up the fronts--maybe.
Yup, amping front L/R ONLY is 99% of the time done for music.
Either amp all the channels, or none.Main Surround -
If you're doing it strictly for home theater, I would go with a 3-channel amp and do center and mains. That way you're still covered for music and your center channel has some breathing room since it handles 60+% of the audio in a surround track.
All that said, don't panic over that S&V article. It's rare that you're going to use 30w/ch, especially if you're running your other speakers crossed over to the sub (since your sub is then handling the low end, which is where the most power is required). Also, S&V's tests tend to be for sustained output and are not indicative of typical transient response (and the fact that few soundtracks use every channel at once at similar levels). Just cross your speakers over at reasonable levels (60-80Hz for the Monitor 70s, 70-80Hz for the CS2, 80Hz for the R150s) and your receiver shouldn't need an amp.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
