Need help on my towers
jhood2880
jhood2880 Posts: 54
edited May 2011 in Troubleshooting
So i bought towers not too long ago. So they are Monitor 70II's. My problem is the right sounds a lot louder then the left. You can clearly tell the difference. I only have had them for a month or 2. How do i go about using my warranty and having them checked out. I am just concerned i that i cant tell which speakers in the cabinet are bad or how they went bad. Do they send replacements? If so how can i determine which are bad? Thanks for any help in advance.
Living Room
TV - Sony 60" LED KDL-60EX700
Receiver#1 - Sony STR-DN2010
Receiver#2 - Pioneer VSX
Front: Monitor 70II's
Center: CS2II
Rear: Monitor 40II's
Sub: PSW505
Master Bedroom
TV - Sony 55"
Post edited by jhood2880 on
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited May 2011
    Call Polk CS? Use the number in the top right corner.
    EndersShadow Posts: 17,727
    edited May 2011
    jhood2880 wrote: »
    1. Check all your connections and make sure they are tight.
    2. Make sure you didnt remove the gold connectors that go between the top and bottom plugs. If you did put them back.
    3. With music playing remove the cover from the speaker having issues. Very lightly put your fingers on each driver. If the drivers are not vibrating, then they are not working.
  • jinjuku
    jinjuku Posts: 1,523
    edited May 2011
    Have you swapped positions to see if the loudness follows the speaker?
  • nguyendot
    nguyendot Posts: 3,594
    edited May 2011
    jinjuku wrote: »
    Yes please do this first and report back.
    Main Surround -
  • jhood2880
    jhood2880 Posts: 54
    edited May 2011
    Thanks for the help. I will trouble shoot myself and then call polk tonight.
    Living Room
    Center: CS2II
    Sub: PSW505
    Master Bedroom
    TV - Sony 55"
