Plasma Wall Mounts? Which one...
TouchOfEvil
TouchOfEvil Posts: 967
edited May 2011 in Electronics
I need to get a wall mount for a 42" plasma set. I was gonna pick one up from monoprice but how do i know if it will work for my set?
I see they have show tv size for each set but is there a way to be certain it will work?
Like my set has screw holes 25"s wide and a 15" space between the height.
Maybe i'm over thinking this, not sure?
Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
Post edited by TouchOfEvil on
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    There is a standard for mounts called VESA I believe and most, if not all new televisions fall within this category. I'd look for VESA compliance.
    http://www.vesa.org/wp-content/uploads/2010/12/FDMI-Overview.pdf
    http://www.mountcenter.com/VESA-Mount-Standards-s/367.htm
  • gdb
    gdb Posts: 6,012
    edited May 2011
    I got a Peerless from Amazon for cheap cheap and it is built like a tank! Very good mount IMO. It has what I'd call universal mount capabilities and is rated to handle up to a 46" panel.:smile:
    http://www.amazon.com/gp/product/B00155X4Z2
  • mantis
    mantis Posts: 17,570
    edited May 2011
    I like Omnimount Plasma brackets but any universal mount designed for a 42 inch TV should work just fine. Peerless and Chief are also good brands. I have no experience with Monoprice.
    Dan
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited May 2011
    If you ever consider changing cables - power or hdmi or whatever, get a swivel mount so you can pull the plasma forward and get behind for 'cable tweaking'.
    I use a Sanus swivel mount - comes in handy.
  • codyc1ark
    codyc1ark Posts: 2,539
    edited May 2011
    I use a $26.00 one from Amazon, didn't know Monoprice carried them in that range, It works great for me. I've got a 46" on it.
  • Face
    Face Posts: 14,340
    edited May 2011
    I have the larger version of this: http://www.newegg.com/Product/Product.aspx?Item=N82E16882021103
    I really like the versatility and aesthetics.
    heiney9 Posts: 25,534
    edited May 2011
    http://www.amazon.com/gp/product/B00080CM30/ref=pd_lpo_k2_dp_sr_3?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B00020M1U0&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1W4NFJ8BSGFCSS0979SC
    This is the Sanus I bought at Amazon for my 42" Plasma. It is very easy to assemble and is rock solid. Highly recommended.
  • Zeros
    Zeros Posts: 940
    edited May 2011
    I can also vouch for the Monoprice tilting wall mount. I have used several of them (one yesterday, in fact) and they always do the job at a great price. With shipping they are usually about $40 for me to the east coast.
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2011
    I use all Sanus brand mounts for my screens. +1 with Doro as well.
    ^ Nice rig in your sig line Zeros, by chance any pics? Sounds awesome.
  • Zeros
    Zeros Posts: 940
    edited May 2011
    Sherardp wrote: »
    Oh, is the showcase working again? If so, I will try to get them up in a day or so.
  • TouchOfEvil
    edited May 2011
    Thanks guys, appreciate the help!!!
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • Geoff4rfc
    Geoff4rfc Posts: 2,981
    edited May 2011
    Check your local Costco if you have one. Mine carries a couple of wall mounts that seem to be pretty inexpensive. I haven't compared any lately so I don't know what's on line these days price wise.
  • TouchOfEvil
    edited May 2011
    Geoff4rfc wrote: »
    No Costco near me. Best thing around here is a Best Buy and no way i'm paying the insane prices they want for one.:eek:
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • gdb
    gdb Posts: 6,012
    edited May 2011
    Hang it high enough on the wall that the floodwaters can't reach it!:eek: I hope you are "high and dry" !!:smile:
  • BWilberg266
    BWilberg266 Posts: 191
    edited May 2011
    +1 for Monoprice
    Very solid mounts for a great price
    Main Setup
    Fronts - Energy RC-50's
    Center - Energy RC-LCR
    Rear - Energy RC-R's
    Subs - Gone...
    AVR - Pioneer SC-37
    Blu-Ray - Sony BDP-S360
    TV - Vizio E550I-B2
    Media Server - Mac Mini
  • TouchOfEvil
    edited May 2011
    gdb wrote: »
    Lol, i should be very good in my place. The flood waters are quite a ways away.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • ken brydson
    ken brydson Posts: 9,038
    edited May 2011
    +1 for Monoprice
    +2 for MP. I got one of their most expensive ones and it was less than $75 shipped. Similar models at BB were pushing $300 :eek:
  • HTaddict
    HTaddict Posts: 13
    edited May 2011
    Check amazon..Got one for like 38 bucks for my 60 inch(145lbs)..nice quality..rated up to 200 lbs..Thats alot of tv..Have several different brands with basically the same design..
  • unc2701
    unc2701 Posts: 3,587
    edited May 2011
    I've used multiple ones from monoprice. No issues at all, and they usually put a warning on there if a model doesn't work with certain TV's (buddy had a pioneer that the cheapest model wouldn't fit and they listed that info in the ad).
    Backburner:Krell KAV-300i
