Denon PMA 2000 enough for LSI15
Jockos
Jockos Posts: 310
edited May 2011 in Speakers
Is the Denon PMA 2000ivr enough juice for the LSI15's. I currently have a adcom 5500 hooked up but I'm concerned with the turn-on and turn-off thump. I can see the woofer cones move. I have the denon stored away in the basement. Any thoughts?
Jockos
Post edited by Jockos on
  • mantis
    mantis Posts: 17,388
    edited May 2011
    I'm sure it will handle the Lsi15's just fine. It's going to be a matter of taste if it sounds as good as the Adcom.
    You could sell both and get something even better.
    Dan
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2011
    I agree with Dan, I'd sell both and step up to the next level
  • Conradicles
    Conradicles Posts: 6,343
    edited May 2011
    Jockos wrote: »
    I would at least give it a try and see for yourself.:cool:
  • megasat16
    megasat16 Posts: 3,521
    edited May 2011
    +1. Denon Integrated are worth giving a shot..
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    heiney9 Posts: 25,432
    edited May 2011
    Give it a shot for giggles, but the turn on thump is totally normal and will not damage anything. My Adcom did that for 20 years and not a single issue.
  • Jockos
    Jockos Posts: 310
    edited May 2011
    Thanks, I just don't like to see the woofers move. I'm thinking about getting the adcom speaker selector to cut of the thump till the amp is on or off.
    Jockos
    edited May 2011
    Jockos wrote: »
    Jockos
    Your willing to add something else in the chain to degrade the sound because your woofer moves a bit :rolleyes:.
    Do what you have to do, but it is totally unnecessary :smile:
