CLUELESS person (me) needs help.
mclebron23
mclebron23 Posts: 20
edited May 2011 in Troubleshooting
Ok, I have polk monitor 60s and a CS2 for a front. I got home today after buying the Onkyo sr608. Hooked the fronts and centers up. When i watch fios tv everything comes through nice and loud through the center but the 2 monitor 60s are really quiet. I can only barley hear when and the sound is only coming out pf the tweeter.
Is this suppose to happen?
Also, i dont even know if i connected the speaker wire from the speakers to the receivers the right way. I stuck the wire in the hole on the back of the speaker terminals but the receiver side, i just twisted the cable around the knob that screws out...is that right.?
Any help is greatly appreciated.
Post edited by mclebron23 on
    edited May 2011
    Welcome to the club first off.
    On the receiver side, when you unscrew the speaker connection on the back of the receiver, look closely, there should be a hole in the middle of the post. Twist the wire and guide it into the whole and screw down the cap. Be carefull not to get any of the plastic outer layer of the cable in the connection, just bare wire.
    Also, did you set up the receiver at all ? Read the manual ? You can't just take it out of the box,hook up wires and be done with it. There is a whole setup process that needs to happen first.
    Also,did you hook up the fios with an hdmi cable to the receiver ? HDMI to the tv ?
  • mclebron23
    edited May 2011
    Thanks for the reply.
    Are you talking about the big facing you on the receiver knobs?
    I didnt read the manual. I 'll read the whole manual on line. I got the receiver for 300$ (store model) at pc richards and the guy couldnt find the manual or remote so he gave me a universal remote.
    Yes, my fios cable box is hooked up with HDMI.
  • mclebron23
    edited May 2011
    i meant to say "big hole facing you on the receiver"
    Thats most likely not it. If not, i still dont see a whole. Do you mind posting a pic of it?
    EndersShadow Posts: 17,732
    edited May 2011
    Did you check the Fios box to ensure that the signal is being sent in Dolby Digital as well?
    Also are their two copper connectors between the top and bottom post on the Monitor 60's?
    You need to connect both sets of post together w/ the copper connector piece, otherwise you will get sound out of either just the tweeter, or just the woofer.
    Also throw in a movie quick. If you get sound out of the Monitor 60's in movie, then its your settings in the Fios box or the Onkyo, if not its a physical connection issue
  • mclebron23
    edited May 2011
    A little confused.
    There 4 posts on the back of each monitor 60 (red black, red black). I connected the top 2 because i was told the bottom 2 is for bi amping???
    By the copper connector piece, you mean that gold plated piece that connects goes around the posts?
    edited May 2011
    mclebron23 wrote: »
    Yes, you are correct, you only want one set of speaker wires connected.
    mclebron23 wrote: »
    Yes, If they are still there then you are fine, I just wanted to make sure you didnt take them off.
  • mclebron23
    edited May 2011
    I did take them off so thats the problem i guess. Does the copper connector go on first then the speaker wire after, or put the speaker wire first and the copper connector on top of it?
    Thanks for all the help guys.
  • mclebron23
    edited May 2011
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited May 2011
    mclebron23 wrote: »
    Actually, that's half correct - you can use either top or bottom for normal use, as long as a jumper is in place. Put the jumper back on first, then install your speaker cable. Make sure you tighten everything snug.
  • mclebron23
    edited May 2011
    I just tried it with the copper connector on first and it worked. Thanks mdaudioguy.
    While you're here can you tell me this.
    When i hook up the surrounds later today, can i still listen in 3.1 or do i have to play in 5.1? Just want to know if i have the option.
    edited May 2011
    mclebron23 wrote: »
    Yes, leave the copper in place that connects the top and bottom posts. Wire goes in the hole of the post and then screw down, doesn't matter if you use the top pair or bottom pair. Remember, no plastic from the wire should be inside that connection, or any other for that matter.
    edited May 2011
    mclebron23 wrote: »
    You have to go through the setup menu and tell the receiver which speakers to play with what input.
    edited May 2011
    Also make sure that ALL four posts with the connecting jumper in place, are 'screwed' down tight. When I first got my M-70s I had no HIGHS because the upper posts were not making contact--not screwed down tight enough. A few twists later and all was fine!
    Good Luck!
    cnh
  • mdaudioguy
    edited May 2011
    tonyb wrote: »
    Yes, but I can't imagine why you'd do that... :confused:
