Computer Speakers
bigaudiofanatic
bigaudiofanatic Posts: 4,415
edited May 2011 in The Clubhouse
Well now that my computer is just about done it is time to search for computer speakers. I am between the Bowers & Wilkins MM-1 and my previous used speakers the Klipsch ProMedia 2.1. The sound card if i used the Klipsch would be the Sound Blaster THX which has gotten amazing reviews.
HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
Post edited by bigaudiofanatic on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2011
    I'm not aware of that sound card, got a link?
  • bigaudiofanatic
    edited May 2011
    newegg.com/Product/Product.aspx?Item=N82E16829102033
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • AsSiMiLaTeD
    edited May 2011
    That's the X-Fi, not the TXH, and that's been out for several years now. Its OK for a gaming rig, would not recommend it for 2 channel music, but then I wouldn't recommend the Klipsch ProMedia for that either.
    So for a gaming rig, that card and the Klipsch would be fine, and that's exactly what I run on my gaming setup, but for music it's not ideal.
    EndersShadow Posts: 17,596
    edited May 2011
    For computer speakers I would go with something like the KRK Rokits, AudioEngine A5's, or something within your price range from Swan. Also are the M-Audio 40's and 30's, but I wouldnt put them in the same category as the first 3
  • dorokusai
    dorokusai Posts: 25,577
    edited May 2011
    What would you recommend for a smoking sound card for <200 Assimilated?
    BAF - How do you go from a 150 pair of Klipsch, to the 450/pair B&W? That's a helluva swing in price range. I'd suggest the NHT M-00 as a contender that's modestly priced @ 249/pair. These and Assimilated's recommendations are all better choices than the Klipsch. I'd pass on the Swan suggestion.
  • shack
    shack Posts: 11,154
    edited May 2011
    I have and like the Promedia 2.1 computer speakers...but I don't play much music throught my computer. When I do they sound pretty good.
  • Jstas
    Jstas Posts: 14,849
    edited May 2011
    All the inexpensive, stellar bookshelf speakers out there from Polk Audio and you're still still **** around with garbage like Klipsch ProMedia?
    Get yourself a set of new Blackstones or a set of used R15's like these:
    http://cgi.ebay.com/Polk-Audio-R15-Bookshelf-Speakers-/280659705319?pt=Speakers_Subwoofers&hash=item41589f3de7
    Then find a cheap integrated or pre-amp and amp and out perform anything you're going to find on any shelf in any computer/electronics store labeled "computer speakers".
    Personally, it's been a loooong time since I've seen computer speakers from any company worth anything.
    I have a set of R15's I ran on a NAD 902 with a Oinker pre-amp as computer speakers for years. I haven't found anything that approaches that combo yet.
    The only "computer speakers" I have are a set of speakers from Polk Audio that they made for SGI years ago. They still serve to impress.
    Expert Moron Extraordinaire
  • dorokusai
    edited May 2011
    shack wrote: »
    You should move up the food chain a little Steve, try something new.
  • AsSiMiLaTeD
    edited May 2011
    It depends on your application. For an internal card I like the Xonar D2X which is right at $200 or the Xonar D2 which is around $170, both from NewEgg so you may find cheaper elsewhere.
    If you want to go the external route there are LOTS of good USB options, but I gave up on that route a while back.
  • dorokusai
    edited May 2011
    Internal for sure. I'll check them out, TY.
  • AsSiMiLaTeD
    edited May 2011
    I don't really agree that the Klipsch speakers are all that bad. They're certainly not up to the task for serious music listening, but for gaming and just background music while you're working they're fine speakers.
    I've run a set of R15 as computer speakers before, and even they are better at music than the Klipsch, but the Klipsch are much better IMO for gaming, they just handle the dynamics better and are designed for short range listening.
    Like I said, it all depends on your application.
  • Jstas
    Jstas Posts: 14,849
    edited May 2011
    I liked the R15's better for gaming. The only benefit that the Klipsch has is the low frequency module but it doesn't dig much deeper than the R15's do. It just plays louder 'cause it's dedicated.
    I hooked up a powered Yammie sub just to see how well it worked with the R15's and for gaming, that set up impressed me quite a bit. The Yammie sub didn't detract from music either.
    I've also run the Amazings as computer speakers just for poops and laughs. My brother is currently running a used Polk satellite system with an old Sony 5.1 receiver for his gaming rig and I'm working on getting him a SurroundBar for it.
    There are way better options out there that I can't even consider "computer speakers" as a viable choice anymore. If it works for you, great but for me, I haven't found anything that I really like.
  • shack
    shack Posts: 11,154
    edited May 2011
    dorokusai wrote: »
    No more listening than I do on my computer they are more than adequate. I have some RT15is, RT25is, some Mini Advents...all of which would probably sound better than the promedia...but then I would need a pre/amp, int amp or receiver to use them. Too much trouble. Now I just plug in my laptop whenever I need to and I'm good to go. Simple and works just fine.
    billbillw Posts: 6,904
    edited May 2011
    I had the Klipsch promedia system and I much prefer my current setup which is a setup of mid-sized book shelf speakers with a decent power 2-ch receiver or integrated amp. I don't feel that I'm giving up anything in bass and the imaging, smoothness and detail is much much better with the bookshelf speakers. I feel they are more dynamic than the Klipsch as well. I'm using a set of discontinued Athenas, but a decent set of Polks would be great too. In near field use, you don't need much power. I had an NAD 40wpc integrated amp that just rocked on my desktop. I later found a good deal on my current NAD receiver (which is rated higher @75wpc), but I don't really see any improvement in sound with the higher wattage. I just like having the tuner at my desktop.
    I say shop around for used gear and for the same (or lower) price, you can put together a nice receiver/amp and bookshelf speaker system that will outperform either of those two computer only systems that you mentioned.
    For rig details, see my profile. Nothing here anymore...
  • newrival
    newrival Posts: 2,017
    edited May 2011
    Jstas wrote: »
    You must have a big desk
  • bigaudiofanatic
    edited May 2011
    I am trying to keep my desk space and not have two large bookshelf speakers and a amp and so on. That is why I was looking at these two.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • newrival
    edited May 2011
    Can you speak to the question of application? There have been good suggestions, but we really need to know your expectations.
    What will be your usage?
    Mostly games?
    mostly music?
    near field/from a distance?
    -the m200 mkiii's are excellent for nearfield hi-fi stereo (you'll probably want a sub)
    -razer mako's are great for games and decent for music
    -audio engines make good near-fielders too but you'll need a sub and i think they're outdone by the swans
    -the b&w's are way over priced IMO
    -Kanto iPair5's are a good choice if you want to plug your ipod into em too.
    -powered moniters could work too but you may find them too analytical. If you like that then krk's or behringer truth 3031A's would suit you well
  • EDUBAG
    EDUBAG Posts: 403
    edited May 2011
    Self amplified audioengine A5, or if space is an issue the A2s. I own the A2 in my office and for desktop I do not feel i need more, and they sound really good and much bigger than they are.
    199, check audioengineusa.com and watch the amazing amount of reviews for the a2.
    I also own the p4 and the n22 amp and posted a review on the p4 here on the forum, i beleive that they are a very good quality product, but if you ask me i believe i should have bought the a5.
    good luck.
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • Jstas
    Jstas Posts: 14,849
    edited May 2011
    Blackstones aren't big at all (6-1/2" H x 3-3/4" W x 4-7/8" D) and an amp/pre-amp or integrated doesn't take up much space especially if used as a monitor stand.
    Even VM10's (11" H x 4-1/8" W x 4-1/4" D) would be a much better step up over even the B&W stuff.
    Hell, the RM series is a good option as well.
    Since all the systems you are looking at have a sub, you can pick up a DSW Pro 440wi subwoofer and you won't even have to deal with any extra wires at your feet.
    Grab a receiver or even a pre-amp and amp from the flea market and you're good to go. Plus, you have the option of running other sources through your receiver or even bypassing to a TV.
    I think you'll be served better with a set of decent bookshelf speakers than any one-box set of speakers for a computer.
  • newrival
    edited May 2011
    I own the audioengine A2, A5, and the Swan M200mkiii's and have to say the Swan's are level more refined than either of AE's offerings and theyre the in same price range. I'm as big a proponant as anyone for AE gear, but it all depends on the listener. Audio engine performs better at low levels in my opinion and has a very analytical presentation, which i like. I feel, however, most people would enjoy the more tube-like presentation of the Swans. They are fuller and livelier and feel more dynamic, which is what many people enjoy, especially for casual listening.
  • bigaudiofanatic
    edited May 2011
    The application is going to be 50/50 meaning 50% games 50% music.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
    edited May 2011
    I don't know that anyone said to use 'Large' bookshelf speakers. A small or medium sized bookshelf is plenty. The slightly larger footprint of a small/medium sized bookshelf speaker on the desk is a trade off for not having to deal with a subwoofer box on the floor. As discussed above, the sound quality is worth giving up an extra 1/2 square foot or so of desk space. BTW, if you put the amp underneath your monitor, you shouldn't notice much, if any, change in the footprint.
    Hey, if you buy used, you can try it and see if it will work for you. If not, you shouldn't loose any money re-selling the gear.
    EDIT: Looks like John already said the same thing. Just a 2nd opinion I guess.
    edited May 2011
    billbillw wrote: »
    I tried that and it ended up moving the monitor waaaayyy to high, so we ended up getting a small HT rack from Target to put the reciever in. So maybe think about that as well. It also will eventually house my 2 channel amp and possibly a printer on top.
    edited May 2011
    ? I don't get it. Is the desk tiered? Is your desk at chest level? Are you sitting on the floor or something?
    For a normal flat desk and normal chair, I think helps by bringing the center of the monitor closer to eye level.
    edited May 2011
    billbillw wrote: »
    Here is a pic of the setup:
    As you can see the actual top of the desk is a bit tall to begin with (hence keyboard and mouse tray). When I added the HK3490 to it I lost a massive amount of space and the HK is about 8" tall so it just looked all wrong and put the monitor up to high. And in all fairness I have the "ghetto lean" when on the computer, and have been known to put my feet up on the desk lol...
    But as with all things YMMV.
  • JimKellyfan
    JimKellyfan Posts: 696
    edited May 2011
    There are speakers on the floor you could use.
    In my living room set up, we have an HDMI and we use the main set up, or the HT, same as watching TV. If not on, then it reverts back to speakers built into our monitor.
    The other office set up, we use our old HT as well.
    Having every disc on our hard drives kind of steered me in that direction.
    And the RCA on the back deck, I hook the lap top to it and get internet radio or network to all our music on one of the other pc's as they are on both. A back up to the back up, if you will.
    Depends on how you use it, I guess.
    If you do Hulu and Netflix through it or what not, it saves from one more purchase.
    As stated, you have speakers in place already.
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2011
    I use the Asus Xonar D2x and it is the best sound card I have used so far. I came from the Creative and Onboard mobo sound chips and the Asus just sounds amazing. They make very good cards that perform well for music and gaming.
    In my own personal PC rig I use the Klipsch Ultra Promedia 5.1 and it does a good job for what it is. I would stick with what you have unless you need the upgrade.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited May 2011
    I never cared for any of the computer speakers on the market, way too cheap for my taste IMO. I don't care for a receiver in the computer area either. I decided to go with powered monitors (M-AUDIO) which for decent quality and small foot print. Depending on the SQ and price point, I just noticed monoprice has some half decent offering; http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10904&utm_source=May_Newsletter_2_g5&utm_medium=Email&utm_campaign=May_Newsletter_2_g5_Email_C_Wall_Mount_Active_Speakers#1090406
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    edited May 2011
    If you're not looking for multi-channel movie decoding or multichannel gaming, I still say you get much better sound out of one of the professional cards, ie: M-Audio Delta, E-mu, etc. High quality output plus high quality inputs (if you ever decide to digitize an analog sound). You can usually find a great used pro-audio card for $50-$75 if you are patient. I paid less than $30 for both mine (Emu 0404 and M-Audio Delta66).
  • AsSiMiLaTeD
    edited May 2011
    I've seen Swan mentioned a couple times, where the hell do you buy them?
