Broken tweeter Lsi15
PhoenixAtDawn
PhoenixAtDawn Posts: 8
edited May 2011 in Troubleshooting
Hi,
My left LSi15 lost high pitch sound and found that the tweeter is not working. I interchanged the tweeter from the right speaker and found out that the tweeter is functional. What is my next step?
I am thinking it is the crossover unit that needs replacing. Any way to test this? Any other troubleshooting tips?
If it is the crossover, is there a detailed instruction on how to replace that unit?
Thanks in advance.
Post edited by PhoenixAtDawn on
  • McLoki
    McLoki Posts: 5,231
    edited May 2011
    bet you it is the resistor in the tweeter circuit (yes, on the crossover). You can solder it back down to the board or replace it. I bet you that is the issue though. (seems to happen in the 15's and the LSiC.)
  • McLoki
    McLoki Posts: 5,231
    edited May 2011
  • PhoenixAtDawn
    edited May 2011
    BINGO!
    My resistor is burnt and CRACKED diagonally.
    One more question. Do I need to take the side speaker out to pull the crossover unit out? It is attached at the top part and I don't want to yank it out.
    Thanks a bunch!
  • Face
    Face Posts: 14,340
    edited May 2011
    What are you using to power them?
  • PhoenixAtDawn
    edited May 2011
    Denon 3805
    I have my Lsi15 set up as "large" speaker on the Denon Receiver.
    Should I have set them up differently? I have used the same receiver for about five years with this setup (Lsi15, Ls1C, LsiFx). I have set all of them up as "large" speakers.
    Thanks.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited May 2011
    LSi's are 4ohm speakers.
    Keep the volume down until you get an amp to properly power your speakers. It's not recommended that you use a receiver them.
    Btw, welcome to the forum.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • PhoenixAtDawn
    edited May 2011
    Ordered the crossover.
    I was browsing thru the forum.
    What do you think about Emotiva XPA-3?
    Thanks.
  • kawizx9r
    edited May 2011
    There are a few that;
    1. Didn't like the Emotiva+LSi combination
    2. Didn't like Emotiva at all for the price
    I have no personal experience with Emotiva so I can't say. When I had my LSi's, they were being powered by a fully modified Moscode 300, and Peachtree Audio Decco and loved every minute of it.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    EndersShadow Posts: 17,713
    edited May 2011
    I also cannot comment on the Emo.
    What I can tell you is that you want to give them as much wattage as you can get. So with the thought of getting the most wattage for your money, I would go with a older used amp.
    Something from Sunfire, Parasound, Adcom, or even Carver.
    I have a set of LSi 15's running on a Carver 705x and they sound good to my ears. I live in an apartment so I cant get them to reference levels by any means but they work great.
    My upgrade next year will be to a Sunfire Grand Cinema amp (450 wpc x5 @ 4 ohm :eek). When I get that bad boy I shouldnt need to upgrade again lol....
  • PhoenixAtDawn
    edited May 2011
    I am very new to this power amp thing. So thanks for all the tips.
    If I am looking for 2 or 3 channel amp for about $700-$1000, what would be the best bet?
    F1nut Posts: 51,881
    edited May 2011
    All you need is a $2.00 resistor.
  • PhoenixAtDawn
    edited May 2011
    I know...
    My board was charred around the resistor, so I figure I wll replace the whole thing and use power amp in the future to avoid it happening again.
    F1nut Posts: 51,881
    edited May 2011
    I know...
    The problem is not the power you are feeding the speakers, it's that the resistor wattage (5 watt) is spec'd too low. Replace them with Mills 12 watt.
  • McLoki
    McLoki Posts: 5,231
    edited May 2011
    Used.
    If you spend $400-$600 on a used 2 channel amp, you could get something pretty killer.... adcom, parasound, carver, B&K - there are a ton of good choices out there....
    edited May 2011
    McLoki wrote: »
    Used.
    ^This
    Get a nice used 2 channel amp with as much power as you can afford and sit back and enjoy.
    Also think about accoustic treatments if possible. They are a great way to make things sound much better without spending a ton of cash.
  • DaveHo
    DaveHo Posts: 3,582
    edited May 2011
    I would go for a 3 channel amp & take the bulk of the load off the 3805.
    Aragon 8008x3
    Acurus A200x3
    Adcom GFA-5503
    Parasound HCA-2003
    B&K 4430
    I have the Aragon 8008x3 now & it's a fantastic amp. Will drive nearly anything with ease. Heavily biased into class A. Previously I had the Acurus A200x3 & it was no slouch either.
    -Dave
  • PhoenixAtDawn
    edited May 2011
    I am replacing the resistor to Mills 12 watt. Someone told me I should replace resistors on BOTH speakers and not just the burnt out one.
    If I replace resistor on just one speaker, would that cause a difference in sound reproduction? Or is it that the one with the orginial resistor has higher chance of burning out again?
    F1nut Posts: 51,881
    edited May 2011
    Correct.
    Both.
  • Face
    Face Posts: 14,340
    edited May 2011
    The one in the other speaker is probably on it's way out too.
