carver tfm-15cb in bridge mode for lsic
deseroner
deseroner Posts: 155
edited May 2011 in Troubleshooting
I was wondering it is ok to bridge with carver tfm-15cb to a lsic
receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
mains-lsi15 4ohm 250w modified&db840 nordost blueheaven spk/rca
center : snell xa1900 4ohm 250w,nordost flatline
subs-klipsch-ksw10/athena asp-4100
rear-OWM3 - 8ohm 100w
surrounds-klipsch rs-7 150w
amp-5ch.-aragon 3005 thx ultra 2 nordost blue heaven ls pc
power.c-bpt cpc/ps.soloist ci.
Post edited by deseroner on
  • Face
    Face Posts: 14,340
    edited May 2011
    It's rated for 2ohm operation in stereo mode, so 4ohms bridged should be fine.
  • deseroner
    edited May 2011
    Face wrote: »
    thanks feel better.
  • deseroner
    edited May 2011
    helo, so bridging in mono 4ohm load is ok, i heard that amps do not like to bridge unless 8ohm. anyone that has tried can chime in.
  • deseroner
    edited May 2011
    its 300 watts in mono bridge
  • Face
    Face Posts: 14,340
    edited May 2011
    deseroner wrote: »
    That's because most amps aren't 2ohm stable in stereo mode.
    edited May 2011
    Why do you want to bridge it anyway ? It's more than capable, if you feel a need to not waste the extra channel of amplification, use one channel for the highs and one for the lows on the center.
  • deseroner
    edited May 2011
    tonyb wrote: »
    i ended up using them for my fxi a4 , they sound great now.
  • deseroner
    edited May 2011
    i did hook the lsic in bridge with the receiver sounds good,it handles the lsic 4ohm no problems. i decided to connect high and lows stereo modes, sounds good also. I decided to use these fxia4 instead , got me another amp for center.
    treitz3 Posts: 20,189
    edited May 2011
    Yes, it's OK but not recommended. The bass gets less than desirable when you do this, amongst other things. Can you say loose?
  • deseroner
    edited May 2011
    so i got a carver/caire bros. maintain pm 1.5 amp for center , this should be ok for the lsic stereo 600watts 4ohm.i did the 300 mono bridgewatt test , no sweat.
  • deseroner
    edited May 2011
    treitz3 wrote: »
    agreed in bridge mode, sounds better now in stereo, cant wait to hook up pm 1.5.
    edited May 2011
    Atta boy.
