Blu-Ray...more
TroyD
TroyD Posts: 13,124
edited April 2011 in Electronics
Hokay, so, took the plunge and bought a new flat screen HDTV and a blu-ray player.....and I'm getting back into HD.
I've got some connection questions....as all I've got is an OLD Denon HT receiver that doesn't have 5.1 or 7.1 analog inputs.
What I did, was run HDMI from the playa to the TV and a coax digital from the playa to the receiver. Now, on standard DVD, this seems to work fine. On a Blu Ray disc (played first one last weekend)....no audio out ot the reciever. WTF? Do I have to have and HDMI receiver?? What if I have a receiver with analog surround inputs (the BR player does have analog surround outputs)? C
JHC, I thought I slayed these dragons years ago...
Help??
BDT
Post edited by TroyD on
  • cheddar
    cheddar Posts: 2,390
    edited April 2011
    Analog inputs will give you lossless audio from a blu-ray player that can internally decode and output analog to the AVR. However, each blu-ray disk should have a DD or DTS 'core' that can be output to toslink and coax for backwards compatibility. But you can't play back lossless using the older digital connections.
    So if you're getting nothing with blu-rays, sounds like a configuration problem somewhere up the chain so the DD or DTS 'core' track isn't selected in the player or being received properly by the AVR.
  • hoosier21
    hoosier21 Posts: 4,418
    edited April 2011
    sell the boat anchor and get a newer AVR
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • TroyD
    TroyD Posts: 13,124
    edited April 2011
    Need a boat anchor?
    BDT
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2011
    keiko wrote: »
    troy, go into the players setup menu, make sure the output is set to pcm and not bitstream. That may be the problem.
    ^ 10-4. Some players even have to have the digital output "activated" to work.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited April 2011
    I doubt the issue is in the player because it's sending the audio to the TV via HDMI if I understand your setup correctly. If that's the case, check the audio out settings on your TV
  • cheddar
    edited April 2011
    Still, the DVDs seem to work, so maybe something not selected properly in the menus of the player...or do you mean this works with another DVD only player not DVDs played by the blu-ray player?
  • TroyD
    TroyD Posts: 13,124
    edited April 2011
    The more I'm thinking...the more I'm thinking I've got the BR player settings dicked up.....
  • olilugo
    olilugo Posts: 405
    edited April 2011
    easy... set it back to factory and start playing with it again :-)
    Current HT setup
    Mains: B&W 804s
    Center: Polk CSi5
    Surround: Polk FXi3
    Sub: Velodyne DLS-3750R
    Receiver: Pioneer SC-07
    Amplifier: Sunfire TGA5200
    TV: Sony KDS60A2020
    DBP: Sony DBP-S350
    CDP: Pioneer DV-48AV
    Interconnect cables: SignalCable analog II
    speaker cables: SignalCable Ultra Speaker Cables Bi-wire
  • mantis
    mantis Posts: 17,394
    edited April 2011
    In the Denon
    Make sure you assign the coax input to the input your using for the Blu ray , I'm assuming DVD so assign Coax 1 to DVD (if you plugged it into 1)
    Also after you assign the Denon input to input correctly , make sure the Denon is set to "auto decode" for incoming signals. Even with the input assigned to the correct Digital input , it still can be looking for a analog signal IF the input is set to look for Analog.
    In the Blu Ray player
    Set the digital out to ON or Bitstream or PCM. This will allow the signal to pass out the Digital coax out.
    Cable
    Make sure your using a quality Digital coax cable , dont use a analog cable which can work but can lose signal due to not being a true 75ohm connection.
    Honestly Troy I strongly suggest getting a new receiver. If I remember correctly you have a modest surround system and don't need anything to high end. I suggest looking at the following receivers and buy one.
    Pioneer Elite VSX21txh used. You can find one around 300 bucks. This is a fantastic workhorse that you can recreate the length of time you owned that damn denon which I think is a avr1901?
    Really I was going to list a few more but now I thought about it , the 21 will serve you well not to mention friends can come over and connect their Ipod to it and you guys can listen to their music as well. Pretty cool it has a bunch of other very cool features.
    If you want something else just let me know. I have some used Denon's laying around the shop that I'd love to move. I'm sure I can cut you a killer deal bro.
    Dan
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited April 2011
    get a friggen blu-ray player with analog outs so you can figure out what your doing and hook it to the analog multi-in on your reciever, dont be a dumb ****, it sort of like a SACD analog hookup.
    RT1
  • TroyD
    TroyD Posts: 13,124
    edited April 2011
    The problem there is, mon frere, is that my receiver (for whatever reason) doens't have multi-channel analog inputs....I think the problem is that I didn't have the output on the BR player correct.
    BDT
  • cheddar
    edited April 2011
    Between the backwards compatibility and the new connections and formats, it's a wonder that anyone is able to dial in their HTs without the help of an installer. But with a little patience and manual/menu searching, things usually work out. Hope you get it figured out. The ps3 I use as a player has seperate settings for DVD and blu-ray playback. So it's possible for DVDs to go to the legacy digital connection and blu-rays to go to HDMI etc. You really have to check nearly every output menu setting to make sure the player's output configuration is what you want it to be.
  • BlueFox
    BlueFox Posts: 15,251
    edited April 2011
    Do new Bluray players still support lossless on analog ouputs, or is it next year when all players will stop allowing that?
