SDA Effect or Sonic Holography
Hawkeye
Hawkeye Posts: 1,313
edited April 2011 in Vintage Speakers
I've been doing some reading and it seems to me that both Polk and Carver were attacking the problem of inter-channel crosstalk from different angles.
While I've enjoyed my time with the SDA, I'm wondering if the Carver approach is more advanced. Not to say one is better than the other, it's just a topic for discussion. I've recently purchased a Carver C1 with the Sonic Holography (I remember these when they were new and couldn't afford it)and comparing it to Polk's SDA process, they seem to have the same intent.
Gordon
2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
Post edited by Hawkeye on
  • SDA SRS 1.2
    SDA SRS 1.2 Posts: 255
    edited April 2011
    Their approach is similar, but I've found the sonic holography to have a much narrower "sweet spot" than the SDA effect and for most listening the SDA effect is much more enjoyable.
    Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
    Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
    Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD! :) )
    nooshinjohn Posts: 25,926
    edited April 2011
    The Carver way was an attempt to adress the problem though electronics, and SDA was a more physical approach. I prefer SDA much more than sonic holography.
    Toolfan66 Posts: 18,063
    edited April 2011
    There is a old thread around here someplace that covers the whole topic of SDA and Sonic Holography..I would like to have my ears on the Carver..
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited April 2011
    I've used my C-1 with a TFM-35 and a pair of Mon 7B Peerless. Setup and dialing it in is tricky. I found the effect varies with the the recording. Just as with SDA, some sounded better than others. The SH has merit when you hit the sweet spot. If you have it in house, hook her up and give it a whirl..
  • TennMan
    TennMan Posts: 1,267
    edited April 2011
    Wondering if the "Phase Control" feature on my Pioneer AVR is trying to achive the same thing? Here is how Pioneer describes it in the manual:
    Better sound using Phase Control
    This receivers Phase Control feature uses phase correction measures to make sure your sound source arrives at the listening position in phase, preventing unwanted distortion and/or coloring of the sound (see illustration below).
    During multichannel playback, LFE (Low-Frequency Effects) signals as well as low frequency signals in each channel are assigned to the subwoofer or other the subwoofer and the most appropriate speaker. At least in theory, however, this type of processing involves a group delay that varies with frequency, resulting in phase distortion where the low-frequency sound is delayed or muffled by the conflict with other channels. With the Phase Control mode switched on, this receiver can reproduce powerful bass sound without deteriorating the quality of the original sound.
  • BlueFox
    BlueFox Posts: 15,251
    edited April 2011
    For whatever reason, neither approach caught on with the public, and both have been abandoned by their manufacturers.
  • Polkersince85
    edited April 2011
    BlueFox wrote: »
    I guess that explains the 125,000 hits on the "Looking for SDAs" thread.
  • Hawkeye
    edited April 2011
    BlueFox wrote: »
    Blue, you're absolutely right. Perhaps folks didn't want to fiddle around with positioning or it didn't fit with the room decor, or any number of reasons. I do believe both of them were on to something that the population hasn't caught up with yet. I'm not a freak on either or, just trying to understand why this science died off and was abandoned.
    Gordon
    2 Channel -
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited April 2011
    I'm sure that if polk thought rehashing the sdas would be very profitable, they probably would. I have a feeling that the size of the cabinets is just one of the big reasons that they would probably be unpopular.
  • Fongolio
    Fongolio Posts: 3,516
    edited April 2011
    TennMan wrote: »
    Wondering if the "Phase Control" feature on my Pioneer AVR is trying to achieve the same thing? Here is how Pioneer describes it in the manual:
    Actually phase control addresses a different problem. Some recordings are actually out of phase (like connecting your speakers + and - backward) and the phase control feature found on many amps and pre amps lets the user control phase to obtain the best sound possible.
    I have lived extensively with both Sonic Holography and SDA's. I like both technologies and would recommend SH to anyone who doesn't have SDA's. As stated, I found the sweet spot smaller on SH but the effect as times can be more pronounced, however I find the SDA effect more natural sounding. One huge advantage of SH is that it can be recored ed. I use a Carver CT-Seven for a pre amp when ripping vinyl and if I leave the SH switch on the resulting digital file has the really wide three dimensional sound stage. There is one area where sonic holography should not be used; when using SDA's. If SH is engaged with SDA's the effect is almost unalienable. Horrible imaging and unnatural sound. Either technology on it's own is very good in my opinion.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
    treitz3 Posts: 19,992
    edited April 2011
    Hello, Hawkeye. I have had, heard and used both the SDA and the Sonic Holography technologies with a plethora of gear, rooms and scenarios. In my observations, Polk did the technology more justice than Carver. The effect can be nothing short of stellar on both but with that said, the SH tends to be extremely picky with both recording and gear while the SDA's perform well on most everything they play. The SDA's also seem to be a little more forgiving with the gear used with them and can sound stellar with both tubes and SS. Many times I found myself turning the SH off. This being due to a slight roll off of the higher frequencies and bass reduction/sloppiness. On the other hand, I never found myself wanting to unplug the SDA cable to defeat its purpose.
    One of the positives of the SH is that you are not limited to one speaker, or a lineup thereof, to use the technology. You can use whatever speaker you want.....except the SDA's and a few select others because you never want to blend the two technologies. Ever. In my travels, SH tends to do better overall with tubes than with SS gear.
    I'm a fan of both and if you want to satisfy your curiosity? That's one thing. If you think that SH will offer you more than the SDA's, you might want to save your money. Both of them can be a challenge to dial in "perfectly" to experience what they both have to offer but between the two? SDA's offer more, for less demanding criteria to set them up properly and enjoy what they have to offer.
    Good luck and have fun in whatever you decide to do.
    F1nut Posts: 51,774
    edited April 2011
    BlueFox wrote: »
    Ummmmm......Polk still uses SDA technology.
    Gordon, I've had both and that's why I still have SDA's.
  • FTGV
    FTGV Posts: 3,650
    edited April 2011
    BlueFox wrote: »
    :confused: I think both companies moved a considerable amount of product incorporating their respective technologies.
  • BlueFox
    edited April 2011
    FTGV wrote: »
    True. I have a pair of SDA-2s sitting in the storage (dining) room. However, it would be nice if I could buy something new today that has either technology, but I do not recall seeing anything like it being sold today.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited April 2011
    ^+1
    Look at the Polk Surroundbar's...
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    F1nut Posts: 51,774
    edited April 2011
    kawizx9r wrote: »
    ^+1
    Right......http://www.polkaudio.com/homeaudio/surroundbar/
    While it's not the same as the original designed for 2 channel music speakers of old, it's way cool that Polk still uses the technology.
  • Face
    Face Posts: 14,340
    edited April 2011
    There are others available in the form of computer DSP's, but they're either very expensive or a very unconventional(odd) listening environment is required. I'm looking forward to inter-channel crosstalk DSP's becoming affordable or even free.
    For those using J. River, there is a crossfeed plug-in available in options, audio, dsp, headphones.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited April 2011
    BlueFox wrote: »
    Not true; Sunfire still offers Sonic Holography on their preamplifiers.
    Gordon, I can't IMAGINE putting that old C-1 in with your BEAUTIFUL rack of MacIntosh gear~ but I think you'd like the result.
    Thanks for the opportunity to have a listen this past Saturday!
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • cfrizz
    cfrizz Posts: 13,415
    edited April 2011
    They didn't catch on in their original formats because the whole thing is simply too geeky for the masses, this also goes for SACD & DVD-A. The vast majority of people simply want to listen to music & watch their movies, including me. I don't really care how it is achieved so long as it works & sounds great.
    I don't want some huge boxes taking up half of my livingroom, I don't care how good they sound. And having the Sonic Holigraphy within my prepro just means I push a button to have it in effect, that's fine.
    There is also the fact that to get that sound you had/have to pay big bucks for it, which most people are not willing to do. And if they were, they would be just as geeky as the rest of you nerds who care about it.
    Having the SDA or Sonic Holigraphy effect may enhance the enjoyment of the music, but it isn't mandatory or essential to anyone who just wants to listen to some tunes.
  • FTGV
    FTGV Posts: 3,650
    edited April 2011
    From a purists stand point the acoustic approach done by Polk would look to be superior.To derive the SH signal electronically Carver add's numerous opamp sections to the signal path.In the schematics I have examined these opamps were rather less than stellar quad units.
    heiney9 Posts: 25,432
    edited April 2011
    Hawkeye wrote: »
    Gordon
    Gordon, no Carver's isn't more advanced. If anything it sounds a little less natural. And also, SDA is not an effect. It's a true aural phenomenon that the SDA's decrease. Inner aural crosstalk is a byproduct of stereo reproduction, the properties of the SDA minimize this. :smile::smile:
    edited April 2011
    BlueFox wrote: »
    Polk still uses SDA technology in a product called "The Surround Bar', perhaps you've heard of it? It took Matt and few engineers about 7 years to develop the advancement in technology to make it possible
    They also used it in the SRT system, they have never completely abandoned it at any point.
    Carver is defunct, has been defunct so naturally it was abandoned.
  • BlueFox
    edited April 2011
    TNRabbit wrote: »
    Yes, you are right. I just revisted their web-site. At least somebody offers this technology for stereo mode. Even if they are doing it in AVRs, not true two channel gear. Also, Sunfire is implementing it via DSP. I wonder if that is better, the same, or worse than the Carver analog method.
    It would be nice if Sunfire would finally offer products that can decode the latest Bluray lossless formats. I remember looking at this gear a few years ago to go with my Sunfire TGA-5400 amp, but passed due to its lack of Bluray support.
  • TNRabbit
    edited April 2011
    BlueFox wrote: »
    I've been supremely happy with mine, but I've been told the dedicated Carver C-9 Sonic Holography Unit is the best representation out there.
    TNRabbit
    Sunfire TG-IV
    edited April 2011
    Here's a diversionary question: I've heard that Carver units with SH are somewhat less than robust in their 'reliability'. I have at least two friends whose units seem to 'always' be in the shop? One says he 'rarely' uses the SH circuit because it sounds so 'artificial'.
    Me, I don't know. I've never heard it so I take everyone's word above until I do. But I can tell you that I'm not dying to hear it because I do have a set of SDAs and they seem more than good enough.
    cnh
  • TNRabbit
    edited April 2011
    cnh wrote: »
    cnh
    Do you know which units? Some of the later models, when Carver Corp had removed Bob & they were busy going into debt to the tune of $11 million, were crappy Japanese/Chinese junk. Hint: look for the oval shaped window~
    I know a LOT of folks with Carver units & while many of them get sent in after the 20-30 year point, that's common as caps begin failing around that time frame....
    TNRabbit
    Sunfire TG-IV
    edited April 2011
    Off hand I can't remember but I'll ask. Around what years are we talking--because I don't really know Carver history that well?
    cnh
  • TroyD
    TroyD Posts: 13,124
    edited April 2011
    I've had both, prefer SDA.
    SH CAN be amazing but it's a real pain in the **** to set up and the sweet spot is microscopic.
    BDT
  • newrival
    newrival Posts: 2,017
    edited April 2011
    heiney9 wrote: »
    As stated above, Sonic Holography is alive and well. It is in every pre, pro. and receiver sunfire has.
    edited April 2011
    newrival wrote: »
    I stated Carver, not Sunfire and Sunfire is no longer associated with Carver or Bob Carver.
    Good to know it's still incorporated in some form in current Sunfire gear. Although, SDA's do it a little more naturally and is easier to set-up and enjoy, especially later SDA's.
    The current Polk surround bars are really incredible considering the small footprint and aesthetics involved. More evolved than the passive process of SDA's, but then also geared squarely at the HT crowd and associated special effects of muli-channel movie entertainment.
    I'd take the passive process of SDA's any day.
