1986 SDA CRS+'s and 1990 SDA 2B Crossovers...
Toolfan66
I have a set of 1986 CRS+'s they have the blade/blade and 2 MW6510's.
My mind was set on doing the 4.1tl mod on them, I started looking at DK's schematics for this mod and saw that it required the pin/blade and the two MW6511's (1990 CRS+) someone said I still could tl these and I just ended up putting it on the back burner, well last week I found a set of 2B crossovers on eBay for $50, looking at the schematics of both the 1990 CRS+ as well as the 2B's they seem to be identical (inductors as well) and should be able to mod my 1996 CRS+'s to the 4.1tl's, I have the RDO-198's as well as the MW6511's, my 2B crossovers came with the pin/blade binding post plates as well with all the wiring harnesses..
Anyone see any reason why I can't do this upgrade/mod with the 2B crossovers?? I think I'm good to go from what I see except placing my order with Sonicraft..
Larry.
Larry.
Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Cary SLP-05/Ultimate Upgrade.
Cary SA-500.1 ES Amps
Cary DMS 800PV Network
Jolida JD9 Fully Modified
VPI MW-1 Cyclone RCM
MIT Shotgun 3 cables throughout / Except TT, and PC’s
SVS SB16 X2
Post edited by Toolfan66 on
As long as you got the 16mH inductor with those 2B crossovers. You've got right crossover and drivers, Your good to go.
Hey you want to sell me the left-over MW-6510's pretty please.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
One difference that may or may not affect the over all results. The pin/blade CRS+ uses a SW102 passive, while the blade/blade version uses the SW100. They will be the same size, just tuned differently.Political Correctness'.........defined
President of Club Polk -
Thanks Jesse, I didn't think about the passives and I think I have 2 SW102's I will have to look.. It's times like these that I'm glad I have a closet full of polk vintage parts!!!Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
MIT Shotgun 3 cables throughout / Except TT, and PC’s -
I just went and looked in my goody closet, I have 2 passives that have no markings not sure if they are SW102's or not..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Larry, there should be hand written markings in white on the back.Political Correctness'.........defined
Nothing on these two Jesse not even a sticker that you sometimes see..The two in the CRS's are marked, and the two I have with no markings look just like the two in the CRS's..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
It's probably Stu's fault......................................runs and ducks for cover.:eek:Political Correctness'.........defined
There is a pair on ebay for $40 but I'm not sure it's worth it..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
I just noticed the little white stickers on the 2B crossovers and they say 2B and CRS.. Looking forward to this project again. I have had them apart for some time now, the rings have been instaled a few months ago as well..LOL..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
Clarity MR caps???:eek:Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
1986 CRS+ 2 piece crossovers..
1990 2B/CRS+ crossovers..
SVS SB16 X2
I think I got a good deal on the crossovers, Wish I had the parts to start upgrading today..Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
SVS SB16 X2
