No center speaker
typonegative911
typonegative911 Posts: 39
edited April 2011 in Troubleshooting
Hooked up speakers to reciever, onkoyo tx-ds939. When i pushed it back into the cabinet negative wire came lose at the reciever center channel. Now i get no sound from center channel any ideas what could be wrong.:mad:
Post edited by typonegative911 on
    Tony M Posts: 11,863
    edited April 2011
    Are you serious...?:biggrin:
  • BlueFox
    BlueFox Posts: 15,250
    edited April 2011
    They need to be balanced. Unhook the postive so that it is the same as the negative.
  • typonegative911
    edited April 2011
    NO no i played the reciever for a while before i realized it came loose, so when i hooked it up right i get no sound out of the center speaker. I know the center speakers good i tested it on another channel. Even when i do a test tone i get no sound from center channel.
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited April 2011
    Make sure it is hooked up correctly, if it worked before, don't see why it wouldn't work now. If it came loose, there isn't any reason it would stop working just because the wire came loose, unless it shorted itself out on something. Try hooking it up to either the L or R Front speaker wires and see if it works then.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited April 2011
    Maybe the center channel turned itself OFF in the receiver's settings. Go into the menu and check.
  • typonegative911
    edited April 2011
    I hooked the center up to another channel and it works. Do you think i could have shorted somthing. reciver never made a sound when playing or anything.
    edited April 2011
    Try doing a hard reset of the receiver and see if that helps at all.
  • mdaudioguy
    edited April 2011
    Have you gone into the menu and verified that the center channel is turned ON?
  • typonegative911
    edited April 2011
    Yea. still nothing.:mad:
    edited April 2011
    Do the reset,if that doesn't work, you fried either a board or a fuse or both, pop the top and have a look see.
  • BeefJerky
    BeefJerky Posts: 1,320
    edited April 2011
    Did you try a different set of wires between the receiver and the center channel?
    Conversely, did you use the center channels speaker wire when you hooked it up to the other channel on the receiver?
  • typonegative911
    edited April 2011
    Yea! i switched wires and all still no luck the reciever still plays fine just no center sound.:mad::mad:
