Help! Can't get Lsi's sounding up to par
I have been struggling to get my system to sound the way it should and creating a sound stage. It could be speaker placement it could be all the settings I've messed with on my receiver to get the best perceived sound.
My Set up
Room is 12x16x9 with a 6 foot opening to enter the room on one side.
Gear:
Polk LSi15 towers
Polk LSiC center
Polk LSiFX surrounds
Pioneer vsx-1120 receiver
Emotiva XPA-5 amp
PS3
Front sound stage is located along the 12ft wall, with seating 14ft back. Speakers are equal distance from side walls, and equal distance to listening position with slight toe-in.
When listening to music, blu-ray, and dvd audio I am not getting clear seperation of instruments and cannot create a sound stage. I have read many links to speaker placement ect. which makes me believe it is my reciever settings. (heck an ancient pioneer reciever paired with wharfdale speakers in a rental beach house sounded better!)
I need help. Is there another source I can look to? Will having the local professional come out to the house even be worth it? Im 6 miles from POLK HQ can they come out or worth a trip there? Im located between Baltimore and DC, are there any other suggestions? Local member help? installer help?
Thanks in advance!
My Set up
Gear:
Polk LSi15 towers
Polk LSiC center
Emotiva XPA-5 amp
PS3
Thanks in advance!
Front Stage
LSi15's
LSiC
Surround
LSiF/X's
Shopping for a sub
Emotiva xpa-5
Pioneer VSX 1120 receiver
PS3
Epson 8350 Front Projector
110" screen
LSi15's
LSiC
Surround
LSiF/X's
Shopping for a sub
Emotiva xpa-5
PS3
110" screen
Post edited by meinbeast on
How far apart are your speakers? According to you they're about 14ft apart which doesn't sound possible.
To achieve better imaging, you might want to pull the speakers away from the walls, back wall and side wall and put them closer together. Experiment with toe-in. A nice point of reference I've heard is to aim the speakers so they point about a foot or two behind your head. This doesn't always work but it's always nice to try.
As far as imaging goes, I wouldn't mess with any receiver settings and just run it direct/stereo. Unless you have something wired incorrectly such as inversing your polarity, speaker placement and room acoustics are to blame, not your gear.2Ch Tube Audio Convert -
I personally would try moving the speakers about 3' from the back wall and close as possible to the side walls (to get them further apart) with enough toe-in so they intersect about a foot in front of your knees. The positioning can be such that a few degrees toe-in difference or an inch movement could make all the difference. I've had a few rooms where the speakers demand precise placement and really did not work in any other position. In such rooms its tedious to find the right placement but once you do its worth it. Take a few hours and play around. In my last room I resorted to trying positions which really didn't make sense to me and one of them worked...
Of course all the other things like speakers being mis-wired (polarity switched on one), mono switch not engaged, sound coming from all drivers should be checked as well.
Do you have a subwoofer ? Did you use the auto calibration on the receiver ? If so, did you have the mic set at ear level in your listening position ? I would highly suggest using the auto calibration if you have not.HT SYSTEM-
lsi 9's -
I have an app on my iphone for this...it may or may not work but worth trying. I also had this same set-up not to long ago. L/R 9'1'' apart from one another, your listening postion (seat) 10'11'' from the front wall, if your using your FX's as sides place them 13'1'' from the front wall, which will be behind you on the sides of yoru walls, if you like as rears find the center of the back wall and put the rears 5'10'' for one another. the front stage should then point to the rears! Maybe it'll help, maybe it wont!!!TV:Sony Bravia XBR4 52'
Mains: Lsi m 705
C:Lsi m 706
Rears: Lsi m 703
Sub: Epik Empire
Pre:Marantz AV 7005
Amp:Sunfire TGA-7400
Blueray: Opp 93
A/V Component: Panamax M5100-PM
Cables: Signal Cable, White Zombie, MIT, Pepster's power cables -
Usually having your seating so close to a back wall is gonna produce some thick mid bass, masking some of the soundstage magic. I agree with Max, move the apeakers out more into the room, and if possible, nudge the couch further up to them. If the mains are on carpet, try spiking them to clay tiles placed over the carpet.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Whatever the issue is, I doubt its your speakers or amp-avr, I am running almost the same stuff diffrent, avr and rear surrounds, and I along with others who comment,are more than a little impressed with the sound, adjustments of some kind should do the trick.Emotiva XPA5, Sony ES 5300,: Lsi 15,s LSIC, Monitor 70,s, ( side surrounds) FXI 3,s, (rear surrounds)Micropro4000, Velodyne DEQ 10, Sony 55inchXBR 930D Sony BDP 790 Bedroom rig SonyES 3200 RTIA1,s CSIA4 FXI3,s polk PSW 10 SONY 34inch XBR960:cool:SONY BDP550
Your using a PS3 as a source right? Think about a Universal player or something that is made to play music if that is the main concern. Or if for HT, you still need to step up from the PS3.
It ALL starts with the source, either movies or music!!
Gordon2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8) -
First off welcome to the forum.
Ok for your speakers I hate your receiver and amp combo. Get rid of all that and get a NAD T785HD receiver. This will give you all the sound quality and amp power. Next it sounds like your positioning is not quite right. There are many rules to follow in order to get the most out of your room with the speakers with in it.
Speaker wire as trivial as some may think , you might not have enough quality there to bring out the best in your sound.
Using the PS3 as a source well depending on your recording quality this could be a good or very bad thing.
To many things it could be , also the fact you just might not like the speakers is always a consideration.
Stupid question but do you have the left speaker in the left position and the right in the right?Dan
A bit drastic, don't you think? He's already spent the money so he's probably stuck with it. He MIGHT be able to get a better receiver in place of the Pioneer but telling him to scrap both is sort of a slap in the face IMO. I would recommend keeping the amp for now but start looking at other receivers. Marantz, Pioneer Elite, NAD, Denon are all good choices.
For music, the PS3 isn't that great. It will get the job done, but that's about it. A stand alone cd player from Marantz or Cambridge Audio is a good bet. PS3 is perfectly fine for Blu Ray but doesn't seem to cut it for anything else.
I agree with Mantis about speaker wire. You can get away with cheap wire but it's definitely worthwhile to look into offerings from companies like Blue Jeans or Kimber. It's also a good idea to make sure you have cables that are up to the challenge. Analog is more important than digital so keep that in mind.
For the 6 foot opening to your room, hang thick curtains to help contain the sound. Acoustic treatments may also be necessary for the rest of the room. If you have hardwood floors, a plush rug will help with unwanted reflections.
My fiance's sister is moving in so I had to move my entire theater from my dedicated room in the basement to the upstairs living room. The dedicated room was fairly well treated and my system sounded great. The upstairs living room is untreated with hardwood floors, opens into the kitchen and has windows EVERYWHERE and my system sounds absolutely terrible.First off welcome to the forum.
Stupid question but do you have the left speaker in the left position and the right in the right?Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
Way to go shooting the guy in the face Mantis. It's all about positioning, then running the calibration to get those things set up correctly. Guy spends a couple grand, then told to get rid of it for other stuff. That would suck if it were true.Shoot the jumper.....................BALLIN.............!!!!!
Who knows. I have lsi25/lsic/lsifx/b&k 7270 sii that I bought all at the same time, hoping to enjoy them and I ended up using them in 5 different rooms, in many different settings with multiple amps/sources and never thought I really got out of them what I should.
Sometimes, I would think they sounded pretty good, but other times, they sounded so bad that I found myself fiddling with settings instead of listening to music or watching a movie.
I spent hundreds of hours troubleshooting, posting on this forum, calling polk, etc. I ended up being so discouraged from the experience that I gave up HT entirely. The speakers ended up sitting in my parents basement for a year collecting dust, until I finally convinced my parents to move them into their living room setup.
To this day, I still haven't quite decided whether I like them or not... maybe if I had given up and sold them 4 years ago, I would have had much less frustration with this whole experience. Or, who knows, maybe not.
edit: I don't mean to discourage the OP in any way. There are too many happy LSi owners to call my experience the norm. In fact, I was met with disbelief when I posted my experience. I just think it is a reasonable concept to consider if your setup agrees with your ears. If you cannot make the system sound good to you, perhaps minor tweaks like cables/speaker position/frequency adjustments simply will not completely change the sound of your system to your liking. -
I am running a similar set-up, and I believe the ps3 maybe be the culprit. Is there another source you can use? Maybe just purchase a new bluray player to test out this theory, and return it if it doesnt pan out. But I have a strange feeling its the PS3.LIVING ROOM:
Emotiva XPA-5, Emotiva USP-1, Polk LSI15's, Polk LSiC, Velodyne 12", Mirage Nanosat Prestige rears, MIT AVT Speaker Cables, Audioquest King Cobra Interconnects, Panamax M5300pm Surge Protection/ Power Conditioning -
way to go shooting the guy in the face mantis. It's all about positioning, then running the calibration to get those things set up correctly. Guy spends a couple grand, then told to get rid of it for other stuff. That would suck if it were true.
lol.ALL BOXED UP for a while until I save up for a new place
Home Theater:
KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
2 Channel:
Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs -
I get superb imaging out of my LSi's so you can too. Like some others I think it's your source. But it's possibly source plus the processing in your AVR. Does your AVR have a Pure Audio or Direct mode that bypasses the DSP? If so try a good CDP with analog out and run it Pure Audio/Direct. Back in the day when I ran off my AVR I learned very quickly that the DSP killed the imaging.SystemLuxman L-590AXII Integrated Amplifier|KEF Reference 1 Loudspeakers|PS Audio Directream Jr|Sansui TU-9900 Tuner|TEAC A-6100 RtR|Nakamichi RX-202 Cassette
Without a strong backbone , the system doesn't stand a chance to perform it's best. He doesn't have to do as I say , he can take it into consideration. Honestly I don't care what he spent , his system doesn't have balance. Position and set them up all you want , if your system isn't balanced , it isn't balanced.
I have no problem telling people this.Dan
HTguru1982 wrote: »A bit drastic, don't you think? He's already spent the money so he's probably stuck with it. He MIGHT be able to get a better receiver in place of the Pioneer but telling him to scrap both is sort of a slap in the face IMO. I would recommend keeping the amp for now but start looking at other receivers. Marantz, Pioneer Elite, NAD, Denon are all good choices.
Why is it a slap in the face? If I went out and purchased a Turbo charger for my car that doesn't fit and a Professional car guy told me to buy one that matched my car , is that a slap in the face because I spent the money?Dan
cokewithvanilla wrote: »Who knows. I have lsi25/lsic/lsifx/b&k 7270 sii that I bought all at the same time, hoping to enjoy them and I ended up using them in 5 different rooms, in many different settings with multiple amps/sources and never thought I really got out of them what I should.
It was a problem with the LSI's when they came out , there was no where really to go hear them. Then the fact they where 4 ohms and required some power to make them sing made it even more difficult. Then when you found a dealer that did carry them , they where connected to an average receiver with little ability to show them off.
In the case of this guy , he has some things against him that could be the reason he is unhappy with his choice. Ok lets try a few things and see if that helps. If it doesn't help , then maybe he just doesn't like his speakers and should move onto something else.Dan
Likely your pre/pro in your Pioneer receiver is causing your problem. Newer Pioneer AVR's have become rather cheap and gutless. The Pioneer Elite AVR's are better, but some people don't care for the sound.
I have a set of Polk Lsi15's, and I am driving them with an Integra 80.2 receiver coupled with a separate power amp. These Polks are amazingly clean, coherent and tight with good gear. And I second an earlier comment about power - these speakers thrive on ample, clean power. -
We all have opinions on this, but unless the OP participates in his own thread, the odds of solving his problems get pretty bleek. Just sayin' is all.HT SYSTEM-
lsi 9's -
To hear that the gear I purchased sucks and that I would have to replace it to be happy is a hard thing to hear. I would be pissed if I just put all that money into something only to be disappointed. You're right though. His gear isn't bad - it just isn't the best match.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
HTguru1982 wrote: »To hear that the gear I purchased sucks and that I would have to replace it to be happy is a hard thing to hear. I would be pissed if I just put all that money into something only to be disappointed. You're right though. His gear isn't bad - it just isn't the best match.Dan
I would love for someone to tell me where my system sucks and how to fix it. I've had people ask me about problems and have found it to be a tricky slope, some are happy to get an answer but most get mad if you tell them they should change something. Many let cost dictate this situation, though it really has no place in the discussion. "I paid $3K for that preamp, its not the problem!"Vinyl, the final frontier...
