SL-2000 & SL-3000 Diferences?
ellenwoods5
ellenwoods5 Posts: 11
edited March 2011 in Troubleshooting
Hey everybody i have a question on the diference between the polk tweeters that are coming from the factory namely the SL-2000 & SL-3000 i purchased two each about 4 years ago and i just recently was looking at all four of them. Now the cardboard containers are marked but the tweeters are not so when i was called away for just a minute then came back i forgot how i laid them out and they look exactly the same and there are no markings on the rear of them so how can i tell them apart can i use a test meter and if so what would the readings be between the two because i swear there is not a lick of diference between the two. Any help at all would be greatly appreciated
Post edited by ellenwoods5 on
    F1nut Posts: 52,149
    edited March 2011
    You must be talking about the RD0194-1 (SL2000) and the RD0198-1 (SL3000). Look on the back at the terminals. One version will have a large and small terminal, the other tweeter has two of the same size. I don't remember which is which, so look at one of your original SL2000 or SL3000 tweeters to get that info.
    Toolfan66 Posts: 18,287
    edited March 2011
    The tweeters with the the same size terminals are the SL2000/RDO-194-1
    The other ones with two different size terminals are the SL3000/RDO-198-1
  • ellenwoods5
    edited March 2011
    Problem solved thanks everyone
