3000 IHT doesn't work with streaming internet?
kimgale
kimgale Posts: 1
edited March 2011 in Troubleshooting
I've got the Soundbar 3000 IHT hooked up to a Samsung Internet TV (LN46C670) that uses wifi.
The speakers work fine with DVD and cable however when I try to stream internet, none of the apps will work when the soundbar is on. ie(hulu, netflix). If I turn off the soundbar, the apps connect fine.
I've tried every 1-4 channel setting on the speakers and the same thing happens.
I've tried moving the soundbar to the floor and as far as the optical cable will allow, nothing.
I have a Dlink DI-624 broadband router, which is probably old, and I'm not sure if that matters or not.
So, basically anytime I want to watch a movie or listen to Pandora, I have to switch the tv back to internal speakers, which kind of defeats the purpose.
Anyone else have this problem?
Help!! Thanks, Kim
