Nice Rotel RTC 850 remote controlled tuner preamp w phono
geppy1
Nice Rotel RTC 850 remote controlled tuner preamp with phono. Classic Rotel unit. I do not have the remote but a simple universal remote does work. Has a nice AM/FM tuner section as well as inputs for phono (Moving magnet and moving coil), CD, AUX, tape 1 and tape 2. It also has two preamp outs to run two power amps as well as 3 AC outlets. Everything works great. Front panel is very nice, top has few scratches and the right rear side panel has a slight ding. Sound quality is above board. Asking $149 Thanks,Keith
Post edited by geppy1 on
Needs to go
PM sent.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
Have you used the phono on this? I am just curious what your thoughts were on it.
Thanks, and GLWTS!
MattMitsubishi 60" HD LDP
Polk RTI-A3 L/R
Csi-a4 CC
Polk CSW 10 Sub
Pio. Elite VSX-03
Pioneer BDP-51FD Blu-Ray
Polk Fxi3s for surround.[/SIZE] -
It is a decent phono section. MM and MC. Nice preamp and tuner Around $500 when new
Bump
Another PM sent.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
